Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 08-28-2005, 09:17 PM
Hfriesen Hfriesen is offline
Removing crankshaft bolt problems
I am changing the timing belt on a 95 cirrus 2.5l v6 and am trying to get the crankshaft bolt out. I've changed timing belts on a number of cars but this one seems very tight. I've wedged a screwdriver in place to keep the crank fron turning (as per Haynes manual). It keeps it nice and steady but I just snapped off the press on shaft on my ratchet. Are these things meant to be that tight or are they reverse threaded as some driveshaft bolts are? I don't want to break the bolt. Any advice?
Old 08-28-2005, 10:45 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Removing crankshaft bolt problems
yeah, you've got a really tight one. try getting a cheater bar along w/ your breaker bar and use that cheater bar to give you extra leverage. I use like a piece of pipe that'll go inside of the breaker bar and just pull w/ all your might, it'll eventually break, just take some elbow grease to get it going.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
