Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-28-2005, 09:59 PM
terpsfan88 terpsfan88 is offline
trunk release
got a 93' super coupe with the trunk release and fuel release in the glove box. the fuel release works fine but the trunk release does nothing. blown fuse? also i have no key to the trunk and was wondering if anyone had any info on getting a key for it cuz the key i use to start isnt the same as the trunk pattern.
Old 08-29-2005, 01:07 AM
coondawg6 coondawg6 is offline
sometimes dealer can cut key off vin number other wise call locksmith not too expensive your trunk lock may or may not be electric some had cables if electric the release solenoid is probably bad
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-29-2005, 01:08 PM
TheDeal526 TheDeal526 is offline
Re: trunk release
the switch can be bad. you should be able to install another switch pretty easy. if you want a trunk switch that looks like the oem switch, you may have to contact ford.
Old 08-29-2005, 05:44 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: trunk release
Take a 12 volt power wire and touch it to the wire going to the solenoid if it pops then it is probably a bad switch if not I would believe it is the soleniod. About the key dealers can usually only do this for vehicles that are a couple of years old so I would try the locksmith.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
