Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-28-2005, 08:52 PM
gandc gandc is offline
Horn And Fluid Not Working
My daughter has a 2001 Dodge Neon. The horn won't work and she can't get her windshield wiper fluid thing to work. I am a mom who knows very, very little. Can you tell me what to check to see if I can fix it myself? Thanks for your expertise. I really appreciate how smart people who know about cars are!
Old 08-28-2005, 10:47 PM
palindromelol palindromelol is offline
Re: Horn And Fluid Not Working
Ma'am, some how i feel a bit grotesque and sticky after receiving disingenuous flattery from a woman. So what ever what happened to Gloria Steinham and Germain Greer? I know. Hillary... she can help ya.
Old 08-28-2005, 11:01 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
gandc, when your daughter presses the horn, does she hear a click sound? If you hear that click sound, it means you have a bad horn. When the washer fluid switch is pressed, do she hear the motor running? If it's running, it could be either low on fluid or one of the lines has a restriction, common to occur b/c those lines are made of very thin rubber.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-28-2005, 11:13 PM
Re: Re: Horn And Fluid Not Working
No clicking sound on the horn. Just dead. Fuses seem OK. I checked the washer fluid hoses, no kinks. Thanks for the suggestions though. Anything else I can check?
Old 08-29-2005, 07:21 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Re: Horn And Fluid Not Working
The horn not working is probably a bad relay, and the washers could be a bad motor or clogged lines.
Old 08-29-2005, 10:49 AM
99 Neon R/T 99 Neon R/T is offline
Just because a fuse looks alright dosent mean it is.Try swapping the fuses just in case.
Old 08-29-2005, 10:50 AM
It's pretty easy to tell the difference between a good and bad fuse, but you never know.
Old 08-29-2005, 11:02 AM
Usually it is pretty obvious unless it burns off to the side instead of inthe middle where you can see it the easiest. Improbable yes Impossible no
Old 08-29-2005, 09:47 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
you may have a worn clockspring. are there any buttons on the steering wheel? like the controls for the cruise control? and if there are, do they work?
Old 08-29-2005, 10:22 PM
make sure if you swap fuses, swap it out w/ one of the same amp rating. Don't switch a 10 Amp w/ a 15 Amp or else you could be asking for maximum smoke and burn up a wiring harness, giving you more problems.
Old 08-30-2005, 12:05 PM
Yeah don't let out the magic smoke.....It's factory sealed.
