Old 08-28-2005, 07:58 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
odd wiring problems
i have a question about wiring with headlights and fog lights and automatic headlights on my 98 camaro i did a few months ago...for a detailed description here it is, for a quick run down go to the bottom....k i looked up how to disable daytime running lights and i found a site http://www.xse.com/leres/ss/drl.html that said behind the radio is the DRL module and that removing the c2 connector will disable DRL's and automatic headlights both and it did...i was pretty happy with that and since i have headlight covers i thought it'd be cool to have the fog lights stay on with the high beams and i found this site http://www.fbody.com/tech/details.cgi?id=9 which said that in the fuse box under the hood to remove the fog light relay and cut the green wire and to tape the end up and to ground that wire to the car which worked....i could turn the turn the bright lights on and keep my fog lights on which was what i wanted but the drl's and automatic headlights came back on so i went back to the first site and removed the light sensor in the dash and removed the sensor and put a wire in the two holes and taped it up and now the automatic headlights dont come on which is good and i can turn the bright lights on and keep my fog lights on too but the DRL's are on again which i want to get rid of...
basically
1) unhooked c2 connector behind cd player which disabled DRL's and automatic headlights 2) cut the green wire from the fuse box for the fog light relay and grounded it so i could keep the fog lights on with the high beams and the DRL's and automatic headlights came back on, 3) unhooked the light sensor in the dash and put a wire in the 2 holes and connected them and taped it up which got rid of the automatic headlights but the DRL's are still on
does anyone know how to disable the DRL's now that all of this is done, i've looked and cant find anything that i havent already tried....thanks!
