Old 08-28-2005, 07:21 PM
patrickswem patrickswem is offline
Send a message via AIM to patrickswem Send a message via MSN to patrickswem
Siezed Engine
So how can I tell if my engine is seized? I have a 4.3 that stalled out about three weeks ago, and wouldn't start back up. It seemed like the starter or solenoid because it would only seldom try to turn over. I put in a new battery with the same results, so I changed the starter and solenoid just yesterday (took a while to get the money), and to my surprise, the starter is still just clicking like it was. I though it may have been the battery as I had tried starting it before replacing the starter without it starting so there could have been a possible battery drain. So I picked up a battery charger and voltimeter. I charged the battery with the (Black and Decker) charger for a while, then being impatient, I disconnected the charger and tested the battery with a result of 14V. That is definately enough to start a vehicle, so I gave it a try. No luck, still just clicking. So is it the engine or is there something else that I can try? I have heard people talk about the ignition switch, but I don't know where it is or how to go about changing it, let alone if it has any part to play in this problem.
Please help, I am supposed to be giving my car to my nephew soon, but I need to be sure I have a vehicle running before that happens, and I have no money to go buy another vehicle.
Old 08-28-2005, 08:53 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: Siezed Engine
try putting a socket on the main engine pulley and see if you can turn it. also check your oil. if u have metal shavings then you might have.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 08-28-2005, 09:25 PM
JC327's Avatar
JC327 JC327 is offline
Re: Siezed Engine
Make sure that the battery and starter cables are in good shape, with no corrosion. Corrosion and damaged connections can play tricks on you - the vehicle can get power and everything seems to be okay, but the starter can't get enough amperage to turn over the engine.
Old 08-29-2005, 06:05 AM
I'll give it a try
I will try the socket trick tonight when I get home, I will also charge the battery more, I guess. I have checked the connections, they are all clean.
Old 08-29-2005, 07:27 AM
Officer Redneck's Avatar
Officer Redneck Officer Redneck is offline
Send a message via MSN to Officer Redneck
Before you try to turn the engine over manually, disconect the positive battery cable!!! We don't want you injuring yourself.
2003 Honda Element EX
2002 Kia Spectra (can't "Improve" or wife will kill me)
1986 Dodge Ramcharger (For sale with a 1966 Rambler 660 classic to boot)
" Idon't know how many of them it would've taken to whoop my ass, but I knew how many they were gonna use. Thats a handy little piece of information to have right there." "Ron White"
http://www.myspace.com/officer_redneck
Old 08-29-2005, 08:13 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Siezed Engine
Good tip! We like our buds to have as many body parts after a reapair as they did before!!!
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
Old 08-29-2005, 01:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Siezed Engine
Also, just because you have 14volts doesn't mean you have the right amount of current to turn the engine over.
You have low vaoltage and need to gain a little more patience and properly charge your battery.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-29-2005, 01:52 PM
Patience???
Lol, yeah, I figured that might be a problem. As I said, I plan on throwing the charger back on when I get home. I was checking at 14 because I thouht that was enough to start the vehicle, and not to mention if my truck wasn't running, I would be driving extra this morning and staying late at work so my brother could use my car to get to work. Luckily, his interview is tomorrow so I have another night to try some things.
Old 08-30-2005, 09:20 AM
Well...
Well, I had a lot to do last night in the house, so all I ended up doing was getting the battery fully charged (according to the battery charger), and read /\14v on the voltimeter (it's as high as this particular model goes). I tried starting, but still only got a click. Didn't get a chance to try turning the pulley, I will try that tonight hopefully.
Old 08-30-2005, 10:37 AM
BlazerLT's Avatar
AF -Advisor
Re: Siezed Engine
I would check your starter before you say the engine is seized.
Old 08-30-2005, 10:41 AM
Re: Re: Siezed Engine
Yeah, already done that. New starter, new solenoid, connections are tight, and when I bought it, I made them test it before I took it home. So I am quite sure the starter isn't the problem.
Old 08-30-2005, 11:11 AM
BlazerLT's Avatar
AF -Advisor
Re: Siezed Engine
I just can't see the engine being seized.
Old 08-30-2005, 11:13 AM
Don't get me wrong, I really don't see a reason why it would be. But I can't really think of anything else it could be. I mean, as I first stated at the beginning of the thread, I don't know much about the ignition switch or if that would have anything to do with the problem, or how to test it.
Old 08-30-2005, 10:13 PM
BlazerLT's Avatar
AF -Advisor
Re: Siezed Engine
The click means something is not moving or is jammed in the starter.
Again, check your wiring going to and from the starter.
Old 08-31-2005, 05:08 PM
Alright. Tried starting it when I got home from work, tried to turn over but then stopped, and again back to the clicking. Took it all back apart leaving the starter on, and had my brother try starting it while I watched the starter. The gear came out but didn't spin. So I dropped the starter, took some spare wire and hooked up a ground to my car's battery, and then hooked a wire to the solenoid and then touched it to the positive post. As with the truck, the starter gear came down but didn't spin. I am assuming this is the problem, so I am taking the starter back to Autozone after I eat some dinner. I'll check back here before I leave, just in case someone sees this post and tells me it isn't the starter. Thanks everyone.
