Old 08-28-2005, 04:58 PM
S10pete S10pete is offline
Changing 2000 S10 alternator
A garage told me my alternator has "excessive ripple" and low charging voltage. They want a fortune to replace the alternator. The vehicle is a 2000 S10 pickup with a 2.2L engine and AC. I'm going to do it myself, so if someone can guide me through the process I'd really appreciate the assist. Also, is a rebuilt alternator OK or should I buy new? What about replacing the belt?
Old 08-28-2005, 07:06 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Changing 2000 S10 alternator
Rebuilt is fine.
Get another shop to test the alternator first though. I've never heard of excessive ripple before and think that they might be trying to con you out of your money.
The job is pretty easy.
Disconect the - battery terminal
You'll have to find the tensioner, use the right wrench to pull it. Slip off the belt (try not to mess up the order that it's layed out in)
Remove the bolts and wires from the alternator, and slip it out.
1 hour tops
Reverse the procedure to install the new one.
2 people make removing and installing the belt easier
Old 08-30-2005, 11:19 PM
ASE Tech1457 ASE Tech1457 is offline
Excessive Ripple
Very Common problem for alternators, they are reffering to excessive diode ripple which is when the diode trio inside the alternator malfunctions. The diode Trio converts a/c (produced by the alt. ) to d/c and when it fails the Alt. is trying to charge your d/c battery with a/c. I run into it all the time, I will try to post a procedure tomorrow, Remember: DISCONNECT THE NEGATIVE BATTERY TERMINAL FIRST!!!!
Reman (rebuilt) is fine I use them all the time and you can get a lifetime warranty on them. get one from Napa, DO NOT BUY AUTOLITE. my buddy is on his 6th autolite in 4 months on his 97 s10 4.3 2wd (good thing he got the warranty huh?)
Old 09-09-2005, 09:00 PM
InOverMyHead InOverMyHead is offline
Yes, but... I have to replace the alternator on my 2001 2.2L 4cyl, and that darn thing is about half way down the engine compartment and not on top of the engine like most alternators. I've got to take some other parts off that I probably shouldn't be messing with to get to it. Can someone explain the easiest way to get to that alternator?
Old 09-09-2005, 10:34 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Alternator is cheap and the replacement is easy.
Do it yourself, it is so simple.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-09-2005, 10:45 PM
Re: Re: Changing 2000 S10 alternator
Yes, I know, I've changed them before. Just saying the one on the 2.2L is hard to get to. Sounds like I need to pull out the coolant reserve tank and maybe the fan cover to make room to get to it as it is not located on top of the engine. You can't get to it with out pulling something out - just physically not possible...
Old 09-09-2005, 10:48 PM
BlazerLT's Avatar
AF -Advisor
You can get it from below sometimes.
How much do they want to do it?
Old 09-09-2005, 11:01 PM
Haven't even gotten an estimate - usually 3-4x what you can do it yourself. I can get to part of it underneath, but it just doesn't look like it can be removed from there. I guess I'll just dive in and hope for the best...
Old 09-09-2005, 11:02 PM
BlazerLT's Avatar
AF -Advisor
check to see how much they want. It might not be that expensive.
Old 09-09-2005, 11:07 PM
Banned
Unless it's a minivan it shouldn't take a shop more than a 1/2 hour to change an alternator.
Say $50.00 at the most in most cities.
A backyard mechanic will charge you about 1/2 that and might even drive to your house to do the job
Old 09-09-2005, 11:24 PM
OK - thanks for the quick responses. Planning to give it a shot in the AM and if get in "Over My Head" will call around.
Old 10-15-2005, 11:58 AM
mountaindew69 mountaindew69 is offline
s-10 alternator
I replaced the alternator on my 2000 s-10 with the same size engine as yours and it wasn't easy but doable. you will need two people for the bottom bolt on the alternator. one on top to hold the socket on the nut and one underneath the cab of the truck with about 4 feet of extensions and the socket wrench. The other bolts come out with only one person. Good luck!!!!!
Old 10-15-2005, 12:02 PM
s-10 alternator
PS: I also accomplished the swap without removing anything else from the engine.
