Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-28-2005, 04:34 PM
talontsi26 talontsi26 is offline
dash lights!!!
I was driving to work when some of my dash light suddenly came on, the radiator light, battery light and emergency brake light. The car still drives fine but those lights aren't going off. What could be the problem?? I tried unpluging the negative terminal on the battery then reconnecting it again but that didn't solve anthing. Any help would be appreciated, thanks.
Old 09-03-2005, 04:10 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Those lights will trigger if your battery loses power. Make sure both of your terminals are on tight.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
