Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 08-28-2005, 04:43 PM
project94sentra project94sentra is offline
Question water problems
ok so i have water in #4 and #2 cylinders. the head isn't craked or the cylinders. headgasket is fine and the head shows no sign of cracks. How did the water get it? i'm perplexed. any suggestions on what it could be?
Old 08-28-2005, 05:09 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: water problems
water or coolant?
maybe it dripped from the passages in the head when you took the head off. it tends to do that.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 08-28-2005, 05:25 PM
it's coolant. i bought it from a guy for $500, he said the engine stopped working. wasnt sure why. so i bought it, put a starter in it and it cranked over but wasnt starting, checked for spark, and coolant was spitting out of the. so i took off the head and 4 and 2 cylinders had coolant in them. checked out everything and now im confused at what the real problem is.
Old 08-28-2005, 08:07 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: water problems
check for warpage in the cylinder head or block deck
Old 08-28-2005, 09:09 PM
Re: water problems
can i check that easily by myself or do i need to take it to a shop
Old 08-29-2005, 03:31 AM
Re: water problems
probably take it to a shop
the level of the block and the head have to be very accurate and it only has to be warped VERY slightly to be out of spec
Old 08-31-2005, 02:21 AM
Re: water problems
so how much would a new head cost and where can i pick one up. is there a special head that i could be looking for, possibly from a bigger or different engine, maybe
Old 09-02-2005, 12:54 AM
Re: water problems
there really arent any head swaps you can do with nissans. to get a valve job and new exhaust valves on my head cost me like 250 but a resurface may be somewhat less than that, not sure
just take the head in and have them tell you whats wrong with it before you do anything else
Old 09-06-2005, 01:01 AM
Re: water problems
so than were is a good place to pick up used heads and how much are they?
Old 09-07-2005, 02:46 AM
Re: water problems
junkyard
dont know how much
