Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-28-2005, 01:02 PM
candycorn candycorn is offline
Question blown head gasket,fixed,but wont start
Hi Everyone:
I am writing in for a friend,.
He has a 1988 Chrysler lebaron, turbo2,130,000 miles,.
He likes the car a lot,especially the turbo.
The head gasket blew out, which he fixed.
He is a very good amateur mechanic.
But now when he tries to start it it just cranks too fast and wont start.
He has changed the sparks,. He has put transmision fluid it the engine to clean the fuel injectors,.
but it still wont start, the fuel pump is new, and the computer,.
does anybody have any suggestions about why it wont start, or what he can try?
thank you,
candycorn.
Old 08-28-2005, 10:48 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: blown head gasket,fixed,but wont start
when he took the head off, did he make sure that he had his timing marks lined up on the timimg belt and the cam gears? Did he also when he removed the distributor, have it pointed to the number one cylinder? If he didn't do either one of those things, it'll never start up.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 08-29-2005, 06:13 PM
roadxing's Avatar
roadxing roadxing is offline
Send a message via AIM to roadxing
I would have to agree with him. i ave an '88 with a 2.5 and i replaced the head gaskets and it slipped out of time. after fixing that it started right up.
Old 09-07-2005, 11:17 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Red face Re: blown head gasket,fixed,but wont start
WHY WOULD YOU TRY TO PUT TRANNY FLUID TO CLEAN INJECTORS!??!!? HONESTY SHOULD YOU EVEN BE WORKING ON YOUR CAR!?
Old 09-07-2005, 11:21 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
First of all, I would never put transmission fluid in the engine at all, it doesn't clean injectors very well. That it prolly isn't very good for the engine at all. When he did the head gasket he prolly didn't torque it down to spec and blew it again or he messed up the valve timing which if it is too bad than it could lead to piston to valve contact which can very rapidly ruin an engine. He will need to readjust the valve timing if its not already too late.
Old 09-25-2005, 09:06 PM
truckdude239 truckdude239 is offline
Send a message via AIM to truckdude239
Re: Re: blown head gasket,fixed,but wont start
why would u put tanny fuild in an motor? its makes brake lines swell shut. i would check timing tough but not to worry that year car should have an non-infercnce motor (pistons have places cut into them so the vavles and pisstions don't hit if timing misses up
Old 09-25-2005, 09:20 PM
nunyo.dambidness nunyo.dambidness is offline
Automatic transmission fluid has a higher ratio of detergents in it than motor oil. The car owner is confused. Tranny fluid was not used to clean fuel injectors. What it is used for is to dislodge deposits in hydraulic lash adjusters, oil squirters in motors that have them, and other tight passages through which oil must flow.
You replace the oil with ATF without changing the filter. Run the motor at idle for 30-45 minutes. Drain fluid, change filter and fill with normal motor oil. This technique is an old shadetree trick that works quite well to quiet noisy HLA's. I've used it on two of my cars, and been pleased with the results.
