Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-28-2005, 12:42 PM
73gmcaz 73gmcaz is offline
Hissing Sound Brake Problem
Hello all!
I have a 1987 with a V6, p/b, a/c. Recently I started hearing a hissing noise under the dash when pressing the brake pedal down and the brakes are not as effective as they should be.
I can say it sounds like a vac. leak and am wondering what under the dash could be the culprit?
Thanks!
Brian
Old 08-28-2005, 02:57 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Hissing Sound Brake Problem
Check your brake booster under the hood.
Old 08-28-2005, 03:22 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Ditto on the brake booster. You may need a new one.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 08-28-2005, 04:14 PM
No noise under the hood...brakes stop ok as far as power boost goes...just spotty as the hissing varies with the leaking vacuum
But the noise sounds like a vac. hose under the dash...is there a vac. line under the dash for brakes
Thanks!
Brian
Old 08-28-2005, 04:41 PM
Sorry for the multiple replies...it's 110 degrees here and I'm working on this thing a little at a time
The noise under the dash is right where the brake pedal rod meets the firewall and goes into the booster.
It is a vacuum leak right where the rod goes in
Any help?
Thanks all!
Brian
Old 08-28-2005, 05:20 PM
More than likely you have an internal leak in your booster.
Old 08-28-2005, 05:52 PM
Bummer
New booster time?
Brian
Old 08-29-2005, 12:12 AM
coondawg6 coondawg6 is offline
yassir, booster vacuum leak at firewall, yassir ,install new or rebuilt unit and noise will go away, yassir , it will
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-29-2005, 08:23 AM
thanks all
Brian
Old 09-10-2005, 04:19 PM
Is there a repair kit for these boosters?
Thanks!
Old 09-10-2005, 11:44 PM
They are non-serviceable.
