Old 08-28-2005, 11:21 AM
darrwing34 darrwing34 is offline
Send a message via Yahoo to darrwing34
98 windstar remote door locks
can someone help me on this? when locking or unlocking using my remote, neither front door will lock or unlock, however the side and read doors work well, both locking and unlocking. is there an easy fix for this?
Old 08-28-2005, 05:42 PM
ruggratt ruggratt is offline
Re: 98 windstar remote door locks
What about when you use the power lock buttons inside? Do all the doors lock/unlock ok then?
Old 08-28-2005, 06:54 PM
sorry, guess I should have mentioned that...no, the locks don't work by using the buttons inside either, but either way, remote or buttons, the side and rear doors will lock or unlock, just not the front
Old 08-28-2005, 11:26 PM
Hmmm.... On my 1996 Windstar the power locks are on fuses #3 and #37 so I think you should check/replace them so we can rule that out. Did both front door locks stop working at the same time? If so then we can probably rule out bad motors/acuators for the locks I would think. Do you hear anything moving in the front doors when you press the remote/inside buttons? If not your problem sounds electrical, maybe a loose wire or something shorting out. Sorry I can't be of more help. Perhaps another member has some ideas.
