Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 08-28-2005, 10:25 AM
1jenriquez 1jenriquez is offline
Question stalling propblem
I have a 95 grand cherokee and it stalls when driven to warm status. I immediately checked for spark and non appeared. Waited several minutes and started up again..to again fail when warm. I have replaced the coil.. HELP
Old 08-28-2005, 12:20 PM
YtseJam454's Avatar
YtseJam454 YtseJam454 is offline
Check the crank sensor
Old 08-29-2005, 09:14 AM
Re: stalling propblem
THANKS!
Old 08-29-2005, 10:18 AM
JeepForever JeepForever is offline
I agree with checking the Crankshaft Position Sensor (CPS). I had similar problems in my '94 Jeep GC. I did a tune-up (replaced plugs, cap, rotor, wires), and it didn't fix the stalling. I was close to giving up on the CPS because it seemed really difficult to get a wrench on the nearly invisible bolt, but from underneath with about an 18" socket extender, I could get to it no problem. That was 2 weeks ago, and it's worked fine since then.
Let us know how it goes!
Old 08-29-2005, 08:23 PM
Ttony Ttony is offline
How can I test the existing cps ?
Old 08-29-2005, 08:42 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Ttony, email me and I will give you the instructions for testing the CPS, altho to get an accurate readin you will have to test it when it fails (stalling occurs).
There are many viarable with stalling, Ignition Coil, CPS, Fuel Pump, just a few.
Here is what I suggest, the next time it stalls recheck for SPARK and also check to see if you can hear the FUEL PUMP kick on: Remove the gas cap, hold your ear close to the filler hole, have someone turn the key to the ON position while you listen for a WHIRRING sound, this would be the fuel pump. if you do not hear the FUEL PUMP kick on and you have NO SPARK, then the CPS would be the cause.
Old 08-30-2005, 04:48 PM
Here's a link to some CPS test info at Autozone.com. It may make sense for someone who is familiar with electrical testing. For me, I chose to spend $60 on the sensor and replace it in about 20 minutes, rather than spend hours fussing with testing (since I was somewhat confused by the testing procedure). Here's the link to an article.
http://www.autozone.com/servlet/UiBr...3d8004f57e.jsp
If this doesn't work, try going to www.autozone.com and search the "Repair Info / Products and How To Info" section. They have good summaries on all types of testing, inspection, and replacements.
Old 09-01-2005, 11:08 AM
Re: Re: stalling propblem
$180.00 can $ plus tax original cps from dealer in Toronto
