Old 08-28-2005, 12:05 AM
jasonsloan jasonsloan is offline
ignition switch harness or blower resistor
I have a 1997 gt.with 3.8. The head lights are dimming to almost off when the ac blower switch is turned on. The blower only blows on low in postions 123 and on high on 45. Dose this sound like blower resistor or ignition swith harness or both. If so dose anyone know the part numbers to both so I can order them through gmpartsdirect.
thanks
jason
Old 08-28-2005, 12:16 AM
jessep28's Avatar
jessep28 jessep28 is offline
Re: ignition switch harness or blower resistor
If your blower motor resistor (BMR) goes out, setting 5 should only work.
Generally if the ignition switch harness is failing your lights should start "freaking out."
I wonder if there is power being drawn when the blower motor is operational causing the lights to dim.
00' Pontiac Grand Prix GT
83,500 mi
Old 08-28-2005, 12:21 AM
jessep28's Avatar
Try these threads:
http://www.automotiveforums.com/vbul...switch+harness
This one makes me think it's harness related
Here is the thread with the part numbers. Make sure they match your car first. If you want to double check, call a GM dealer and ask for a part number. They typically won't question it .
Good luck. Both the resistor and harness tend to be an issue. However, since it's not just the fan, I am almost positive it's the harness. However, I am not an expert.
83,500 mi
Old 08-28-2005, 07:00 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
One thing you want to do before repacing any parts is to perform a little diagnosis.
Check the basics first..do you have a good battery and a good charging system?
If battery voltage drops, wierd things could happen .
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
