Old 08-27-2005, 11:19 PM
gastube gastube is offline
fuel pump prob and gas guage wont work
93 grand am need a wiring diagram of electrical fuel system ,no power to fuel pump
Old 08-28-2005, 10:34 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: fuel pump prob and gas guage wont work
cheked the fuses and relay in the fuse box?
Old 08-28-2005, 10:37 AM
Try here for a diagram. it says 98 at top but covers 85-98.
http://www.autozone.com/servlet/UiBr...3d8009d024.jsp
And Welcome Gastube !
Old 08-28-2005, 09:44 PM
tdinning tdinning is offline
Had this exact problem with my '93 GA, 3.3L
Prev. owner had installed two new fuel pumps and a new relay, and still had the problem. I lucked out and noticed that the pump harness plug where the harness plugs in above the rear axle had one terminal that looked wider than the others. Solved by inserting a small piece of stranded wire in the suspect female plug terminal and reinstalled. which apparently tightened things up. Pump and gauge now run perfectly.
Old 08-29-2005, 08:29 PM
Fuel pump
Thank T I will check that, do you know ,if the fuel pump has siezed up could that cause the guage not to work, ws suggested by a friend
Old 08-29-2005, 08:33 PM
Re: Re: fuel pump prob and gas guage wont work
Thanks X cecked all that ,fuses all good relays all clicking, Ill check that wiring diagram
Old 08-30-2005, 04:30 PM
Re: Fuel pump
Don't know if siezed pump would cause gauge malfunction. I do know that there are only 3 wires going to that fuel pump. Figure out 12v + and - on the wiring diagram, noting which polarity is which color wire; unplug the pump harness above the rear axle and jumper the correct 2 wire terminals with a good spare battery. Should tell you if the pump works, or if your problem is elsewhere. You might get a spark so watch out for any fuel leaks.
Old 08-30-2005, 06:12 PM
the gauge/pump are connected inside the tank. if these came loose for some ungodly reason, they wouldnt work.
Most fuel pumps I seen go bad because the filter on the pump inside the G. tank get holes large enough for debre` to enter and seize the pump.
