Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-27-2005, 10:20 PM
abellana abellana is offline
Send a message via Yahoo to abellana
Aircon blower switch only respond to level two higher, not level one
When I turn the aircon switch to level 1, the fan would not run.. However, if I put the fan switch to level two it will.
The compressor fortunately seems to be responding to switch one.
Is there a quick fix to this problem or should I call an electrician.
Thanks in advance
Old 08-28-2005, 02:45 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Aircon blower switch only respond to level two higher, not level one
The problem is with the blower motor resistor located next to the fan. The resistor is available from a dealer for about $40 and is not hard to replace. I really don't know where it is located on the Montana.
Old 08-28-2005, 03:36 PM
GregA's Avatar
GregA GregA is offline
Re: Re: Aircon blower switch only respond to level two higher, not level one
Originally Posted by GTP Dad
... blower motor resistor located next to the fan. ... I really don't know where it is located on the Montana.
Should be behind the insulator panel, passenger side (where the passenger's feet would be).
You may have to remove the blower motor to get access to the resistor assembly. Should be a relatively simple job.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
