Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-27-2005, 07:15 PM
SSZero's Avatar
SSZero SSZero is offline
Check Engine...
Does anyone know how to get a P0170 (Fuel Train Malfunction) and a P1104 (Fuel Air Metering Malfunction) codes fixed? I know my MAF sensor may need replacing for the P1104 code, but for the P0170, is that due to my fuel injectors or waste gate solenoid? Any input would greatly be appreciated. Oh, and this is a stock 96 Eclipse GST Automatic with almost 70000 miles...
'96 Green Eclipse GS-T
Stock for now...
Old 08-28-2005, 12:00 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Check Engine...
It may both be related. I'm not positive, so don't take my word on this. Usually when there is one problem, espcially with the MAF, it could cause lots of other problems. The MAF is alarge part of the whole A/F system, so it could be causing a bad signal to the ECU, which is making the ECU send little to no fuel to a FI. Get the new MAF first, then see what happens. Best of luck
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
