Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-27-2005, 04:52 PM
glitcher50 glitcher50 is offline
Angry airbag light
Hello,
I just replaced both airbags after they have been deployed. But the airbag light remains on. Is there anyway to reset this light??
Thanks
Old 08-28-2005, 11:45 PM
palindromelol palindromelol is offline
Re: airbag light
Apparently, you can clear the light by "clearing" the codes. That can be done by lifting the Neg Battery terminal for 45 seconds. Das2123 suggests a fuse, but I can't recall which one to accomplish the same thing. Das.....??
Note. according to the BOOK.. if the light is on it may indicate a malfunction in the ACM or in the airbags themselves. THE ACM (airbag control module is located between the seats underthe plastic console just ahead of the brake lever).
I don't like messing with pyrotechnics and I suspect the virually empty thread is indicative of people having the heebee geebees when monkeying with airbags.
notwithstanding that.... clear the codes and check your work. Apparently there is a Passive Restraint manual... I don't have it. Hey!!!! It might be one of the impact sensors. Collisions have a way of breaking things.
Old 08-29-2005, 10:56 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: airbag light
Pulling the fuel pump fuse for about 5-10 minutes will reset the PCM, I don't know about clearing the air bag light.
Old 08-30-2005, 11:27 AM
It probably is the impact sensor, since the car did sustain a pretty big front end collision. I did replace the control module, thanks for the location! Where can I find the front impact sensor? Is there just 1?? And can I just buy these at Murrays or an Auto store??
Thanks
Old 08-30-2005, 12:14 PM
99 Neon R/T 99 Neon R/T is offline
Re: airbag light
They should be behind the front bumper.If you lay on a creeper and roll under the fromt corners just look up.I think they are a dealer or junkyard item,but it never hurts to ask.Give Murrays a call.Yhe worst they can do is say no.
Old 08-30-2005, 04:17 PM
Re: airbag light
There are 2 on my 96 neon.
