Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-27-2005, 05:47 PM
needqajob needqajob is offline
Need Healp! Driver side door can't be unlocked in 1992 toyota camry
92 camry
I cannot open the drivers side door because it will not unlock. This problem is only with driver side switch. Front passenger side switch works perfectly( It unlocks rest of the three doors)
Does anyone know how to fix this? Ive tried pulling the lock to the unlock position but it stays locked. If I stick the key in to unlock it, it tries to move lock/unlock button but still does not work. Power Door locks wont push it unlocked either. I've tried prying it the handle but it stays locked there.
Please Advise. Need help badly
Old 09-16-2005, 02:29 PM
cl33ee cl33ee is offline
I have a 93 with the exact problem. Same door, same everything.
Old 09-16-2005, 05:37 PM
Re: Need Healp! Driver side door can't be unlocked in 1992 toyota camry
How did u solve problem. I still have problem i showed two of my mechanic friends and they do not have any solution except cutting door lock. I can't open door panel since door is closed so all screws are covered.
Let me know if u have any suggestion
Old 09-16-2005, 06:15 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Try a slimjim
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-16-2005, 07:20 PM
Re: Re: Need Healp! Driver side door can't be unlocked in 1992 toyota camry
Not fixed yet. A slim jim is a possability........It has plenty of "volts"; I'm gonna try lots of lube next............
