Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-27-2005, 04:07 PM
Phill104 Phill104 is offline
Question Under Drive Pulley
Is it harmful to beiefly run a neon 2.0 SOHC engine without the
under drive pulley ( harmonic balancer ? ) installed.
Old 08-27-2005, 11:43 PM
palindromelol palindromelol is offline
Re: Under Drive Pulley
Crankshafts are first statically balanced. That is, without pistons etc, the crank is perfectly balanced. So is the harmonic balance pulley. It is also balanced perfectly. Then all the bits and pieces are made to weigh about the same as each other. So it is natural to ask why would one need to have a harmonic balance present? What does it do?
It Dynamically counteracts the reversed bending that results from the crank being in motion, and supported by the bearings in a nonuniform way.
The harmonic balance is particularly useful in counterbalancing this bending effect at a particular rpm. In fact, normal cruising rpm. Ever notice that the engine has a nice quite cruising RPM where everything is quiet. That is no accident. The flywheel does the same thing. It is a cantilevered mass overhanging the main bearing about the same amount as the harmonic balance.
The balance likely does nothing at low rpm. It does a whole lot at high rpm.
So what speed are you intending to run the engine? If I were you, I'd put it on in case you get tempted to do an experiment in engine vibration.
Great article on balancing here:
http://www.aa1car.com/library/2003/eb10330.htm
I was always concerned I break something if I buzzed the engine without the HB.
Old 08-28-2005, 09:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
How briefly? Because without the balancer your alternator will not be working, therefore not charging the battery.
Old 08-28-2005, 07:08 PM
Smile Re: Under Drive Pulley
Thanks for the great information. I replaced the timing belt and tension idler and just wanted to crank it briefly at idle to see if everthing seemed ok before I put it completely back together. Didn't want to wrestle with the pulley twice if i didn't have to. Ran it for a couple of minutes and it sounded great. Thanks for sharing your knowledge.
Phil
Old 08-28-2005, 07:16 PM
Re: Re: Under Drive Pulley
I hope you did the water pump too!!!
Old 08-28-2005, 10:42 PM
Great. Weren't tempted huh? what about the flywheel? was it on?
