Old 08-27-2005, 11:30 AM
Rollingbones's Avatar
Rollingbones Rollingbones is offline
Question boogered radio question!!
I have a '02 LT x-cab with the stereo/single CD/Bose speaker setup. The last few months it's developed an interesting habit. Sometimes I get an annoying static out of the front speakers when I first turn it on (not the rear and it sounds at first like a blown speaker) . It goes away after a few minutes. It does it most, but not all the time and when it's working properly, the sound is good. It does it with either CD or radio. This leads me to believe that it's the radio and not the speakers which is malfunctioning.
QUESTION: Is anyone else our there in cyberland having this problem? Is there a cure other than taking it in (I hate having to do that)? I have a feeling I need an appointment!!!
2002 Superado, LT (Carmine Red), 5.3 L
3.73 RR, Flowmaster, K&N FIPK Cold Air Intake,
160 T-stat, Hypertech Tune, Towing Pkg.
More pics here: http://www.cardomain.com/ride/2091584
HAVE A NICE DAY...
...Unless you have other plans!!!
Old 08-27-2005, 04:32 PM
nineball481's Avatar
nineball481 nineball481 is offline
Re: boogered radio question!!
Well, I used to have this problem with my '76 Lincoln. The back speakers would hiss/crackle when I turned them on. They would go to normal after a couple minutes.....and sound great. Its like my speakers needed to warm up, to run smooth. Unfortunately, I have no remedy for this problem.....So I can't help you. Sorry
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 08-28-2005, 03:29 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
welcome to the bose stereo. i would say the bose amp is going out. and i am not sure where it is located but the radio and speakers are most likely fine. if you want to replace the amp it will cost a pretty penny. ur best bet would be get a new cd player aftermarket and run new speaker leads from radio to speakers. will give better sound quality and will get rid of stock junk. thats my opinion
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-28-2005, 03:57 PM
It's under warrenty....the next one is free!!!
HAVE A NICE DAY...
Old 08-28-2005, 04:55 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
That is interesting to hear that the stock "Bose" is junk. And especially if the replacement is free.... I have ridden in quite a few trucks with aftermarket stereos worth $ and in my opnion they are equal. Each to his own.....
Old 08-28-2005, 06:42 PM
they sound fine till they have problems and then they are a headache. i install for my job and bose is a pain to work with. just my opinion. they have alot of problems over time even if you are easy on them.
Old 08-28-2005, 06:53 PM
Very interesting indeed. I have a pair of Bose 901, Series IV in my family room.... but that's in the family Room. Been there awhile...Niiiiice speakers!!!
HAVE A NICE DAY...
Old 08-28-2005, 06:57 PM
anything you buy from a store is gonna be nice bose stuff, but all that is in your truck is a cheap bose amp and everything else is the same as any other truck. they charge you like 500 for the option and really should cost like 100.
Old 08-28-2005, 08:38 PM
jethro_3's Avatar
So you are saying the speakers that say Bose are not????? And that the standard 8 ohm seakers hook right up to the 4 ohm system???? Now I am really lost in the cheap seat section......
Old 08-28-2005, 10:30 PM
they are bose but are not really high quality bose speakers like you would buy from a store. maybe i am wrong but i have never seen anything really that great of quality from a factory system.
Old 08-28-2005, 10:51 PM
another example of the quality is in chryslers that have the infinity system in them. the speaker are just cheap paper speakers and aftermarket infinitys are alot better quality by have rubber surrounds and silk dome tweeters. bose does not make car audio except for factory gm's. all im saying is it my opinion bose factory systems are not all that they seem or say they are.
Old 08-30-2005, 08:55 AM
Angry
I was taking a careful listen this morning on the way into work...The front speakers really do sound cr@ppy. I'll have to pull the grates over them and take a look and see how they compare to a high quality Bose home speaker....Bummer Guess I might have to add some stereo stuff to the wish list.
HAVE A NICE DAY...
Old 08-30-2005, 08:51 PM
when taking the speakers out you must remove the door panel, the grills do not pull off. the door panel is easy to take off. a couple 7 mm screws under handle and it should lift up and unplug all connectors .
Old 08-30-2005, 09:31 PM
Thanks for the input!!
Old 08-30-2005, 11:20 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
My old '84 Olds Toronado (my high school pimpmobile that I REALLY loved) had a factory Bose system in it. It worked pretty well.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
