Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-27-2005, 08:23 AM
bottoms66 bottoms66 is offline
Changing alternator belt on 2.5
I have to replace the belt on my 86 with 2.5 ltr. Do I have to remove the drive belt first? If so, how do I do that? I was looking for a place where I can loosen a pulley but couldn't find a place. I'm a novice just looking to save money, all help appreciated. Thanks.
Old 08-27-2005, 11:32 AM
tri-power's Avatar
tri-power tri-power is offline
If you have a multi belt setup then your adjustment will be on the components like the alternator and such. There will be no tensioner pulley. They were designed for serpentine belts.
Old 08-27-2005, 12:25 PM
Re: Changing alternator belt on 2.5
I found adjustment on the power steering pump. I loosened the two bolts for the adjustment but it is not budging. Help.
Old 08-28-2005, 10:22 PM
Mailman1 Mailman1 is offline
If it is like most of the power steering pumps on the 2.5 there are three bolts that hold the power steering pump. You might of missed the one under or on the bottom of the pump.
Old 08-28-2005, 10:31 PM
tri-power's Avatar
The bottom bolt is usually located behind the pulley,and will require you to put an extension through the holes in the pulley to remove.
Old 12-07-2005, 11:09 PM
valvolinexc1 valvolinexc1 is offline
I have this same car and had to replace belt also, I just unbolted the alternator to get the belt loose.
