Old 08-27-2005, 07:37 AM
rustcal rustcal is offline
Send a message via AIM to rustcal Send a message via Yahoo to rustcal
leaking battery warning
heads up. i had a ac delco battery put in my truck 2 yrs ago. the other day when i went to start my truck it wouldn't start. when i went to wiggle the connections the positive cable fell out of the battery. talked several people in the auto service industry and they all said it is very common for ac delco batteries to do this. the place i got it said they wanted $40 dollars to replace it and that since it is a replacement battery that it would not have ANY warranty. I called ac delco and all they kept saying is that and I quote " we make quality products ". So if you have a ac delco battery check you positive terminal it see if it leaking, if so I hope it is under the 18 month wty. but either way replace it so your not stranded somewhere.
FYI: i will never buy another ac delco battery. my friend that works at a dealerships in the service dept said that diehard batteries are pretty good choice, for what it's worth.
Old 08-28-2005, 08:59 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: leaking battery warning
I just experienced that two weeks ago. My Ac Delco battery in My blazer did that 8 years ago too. I've always replaced batteries with Canadian Tire Batteries. That way if I'm ever on the road anywhere in Canada and I have battery problems I can just go to any Canadian Tire store and get it replaced.
3 Year Free Replacement, 9 Year Pro_rated Replacement $100 CAN. I've always had these batteries and never had any problems. Ruddy AC'Delco batteries; oh well at least I got to spend a few minutes cleaning up my Battery Tray...
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 08-28-2005, 03:25 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i see this alot on gm's when i do installs on them. the battery's are junk and you might as well replace it with a optima red top or yellow top and get it over with. before you get stranded.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 08-28-2005, 04:42 PM
chuck16's Avatar
Optima?
Are those the batteries that if you run it down you can just unplug them and they charge themselves back up again? I've only heard of rumors where guys kill their batteries and then they just unplug the battery for a few hours and it gets enough juice to get you going again????
I just like the idea of having a battery that I can take to Canadian Tire if I ever need a Warranty Replacement.
Speaking of which, I wonder how long batteries actually Last? I've only ever gone through one battery one every vehicle I've owned. The longest stretch was almost ten years and only one battery????
2008 GMC ACADIA
I AM Canadian!!
Old 08-28-2005, 04:46 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
I have the Optima Red Top. Long warrenty, GEL, and never have run that 900 cca down yet even with stereo for a day. Worth the money.
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 08-28-2005, 06:44 PM
i dont know about charging themselves, but i have seem real good luck with these and have never had or seen one die. they are very dependable and they are gel, so no more liquid.
Old 08-29-2005, 09:29 AM
Vortec327 Vortec327 is offline
It is common for the lead side terminal "puck" to fall out when terminal bolts are too long or overtightened....I used to work parts at Canadian Tire and took in a lot of batteries like this. That is a reason why the batt cable bolt head is so small (requires only a small amount of torque).
2004 Silverado LS 5.3L 2WD
1995 Camaro Z28 5.7L LT1
Old 08-29-2005, 10:50 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I use Interstate Batteries because I simply cannot afford an Optima. I used to sell Interstate batteries at the shop where I worked and I love the hell out of them. GREAT warranty too.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-29-2005, 10:58 AM
Re: Re: leaking battery warning
i thought interstatw made a optima battery, or one really similar to it. i could swear i saw one not to long ago??
Old 08-29-2005, 11:02 AM
jeverett's Avatar
They do, and I'm not sure about the price. I forgot all about that though. I'm kinda partial to Interstate, I might have to look into this. Thanks for reminding me
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-29-2005, 11:16 AM
waitingforcolumbus waitingforcolumbus is offline
My Delco did that too. Acid filled the terminal and part off the cable's jacket. I cleaned the area with a gallon of water and baking soda.
I have an Optima. They are now owned by Interstate.
Old 08-29-2005, 01:53 PM
Faze3's Avatar
Faze3 Faze3 is offline
Not only did my Delco battery leak, but the leaking acid took out the pump on the wiper reservoir tank. Just an FYI. Easy to replace though.
