2002 chevy won't start
i was riding down the road then lost power and the truck was running but had no power. then i shut it off and now it won't start back. it trys to start but won't. can someone post some trouble codes so when i get it run on the puter later to day i'll know the code means.
thanks matt |
Re: 2002 chevy won't start
how's your alternator?
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
Once you run the diagnosis, go on line and do a google search on "chevrolet computer coses". "GM computer codes" will also yield a lot of results as well.
![]() 2002 Superado, LT (Carmine Red), 5.3 L 3.73 RR, Flowmaster, K&N FIPK Cold Air Intake, 160 T-stat, Hypertech Tune, Towing Pkg. ---------------------------------------- More pics here: http://www.cardomain.com/ride/2091584 ---------------------------------------- HAVE A NICE DAY... ...Unless you have other plans!!! ------------------------------- |
Did your SES light come on before this happened?
Is this an engine spins and won't start or a I turn the key and the starter clicks problem? This little bit of info will help you in getting some answers also do a search..losts of threads on no start concerns. You need 4 things to make an engine run...Air, Fuel, Spark and Compression Start by checking those first.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
is the security light flashing?
thanks for all the replys, it turns out that i need a fuel pump. i got under it and beat on the tank while my wife turned the key and after a few hits it started right up. so NAPA is about $300 dollars richer now. again thanks for the replys.
is it me or do the fuel pumps go out alot on these trucks? seems to be a common problem.
2002 CHEVY SILVERADO more pics at http://www.cardomain.com/ride/2228127 ![]() ![]() ![]() ![]() more pics at http://www.cardomain.com/ride/2228127 |
Matt,
Had the same thing happen to me. I also thought it was the fuel pump and almost replaced it. Then it happened again and I took it to dealer. They replaced the distributor cap $250. Then it happened a third time. Took it back and they replaced the whole distributor. After much complaining I did not pay. A month ago I got a recall notice about the distributor and chevy refunded my $250. So check to see if there is an open recall. |
Re: Re: 2002 chevy won't start
![]() It's not a question of "if", it's "when". Kept our '02 Tahoe LT only 3 months. It was very nice, but 2 fuel pumps (plus the one that was replaced by the previous owner) and a front hub/ bearing was too much. No truck is that nice. When I told my wife that I had put a rubber mallet in the back so she could get the thing started by herself and save me the trip, she said "That's it. Put the pile of s**t out by the road with a sign in it." Sayonara. Hated to see it go. Must be a glutton for punishment. |
FYI 2002 silverados do not have distributors
