Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 08-27-2005, 06:59 AM
gmcpct gmcpct is offline
Rough idle and acceleration
91 S-15 Jimmy. I checked the board and have seen some similar posts but not exactly. Idles rough in gear, not so much when in park or neutral. Bogs down sometimes when accelerating. When the truck hits about 40-45 mph it starts losing power - If I can ease into it, its usually ok but if I have to get on the gas it starts to bog down.
Have done a tune-up and theres no change there.
Service Engine light Does Not come on, Does Not run hot. air filter and Hoses all look ok, Thinking its the cat converter?
Old 08-30-2005, 10:48 PM
ousooners1baby's Avatar
ousooners1baby ousooners1baby is offline
fuel filter?
Old 08-31-2005, 03:07 PM
Have since changed the catalytic converter, pcv valve and fuel filter and still have the problem. I cant think of anything that would cause this issue but not make the "service engine soon" light come on?
Old 08-31-2005, 03:58 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Rough idle and acceleration
Look at your injectors, are they spraying a nice cone or do they have drips?
Old 08-31-2005, 05:00 PM
Have been mixing in some marvel mystery oil over the last couple of weeks with no change in performance but I'll check the injectors.
Old 08-31-2005, 08:41 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Unplug the vaccum line going to the EGR valve(on top of EGR), leave it unpluged and take it for a drive, see if this helps.
Old 08-31-2005, 09:58 PM
Thanks, WIll try that with the vaccum line tomorrow and see how it goes.
Old 09-01-2005, 08:41 AM
I Unplugged the vaccum line from the egr valve but it didnt solve the problem.
Old 09-04-2005, 11:24 PM
blazes9395's Avatar
Newbie mod
Did you check vaccum pressure, or did you do compression test on the engine to make sure it is healthy? I mentioned EGR just in case, it was somethinglike that. If all that checks out, I had something similar on my 89, where it bogged down, and just ran like it was out of power, yet idle was great and stuff. I tried everything, and finally I got it, turned out being the coomputer was garbage, not bad enough to cause it not to run, but bad enough to loose power. I went and bought a used computer, put my chip in from my truck, and problem was solved. I don't know if thats your problem, but I thought I would mention this too.
Old 09-06-2005, 08:01 AM
I went through the boards and started making a list of the possibilities for this and figured I'd eliminate them from easiest/least expensive on. Hoses were fine, Someone mentioned in a post that they had a problem with the wiring harness to the IAC. Went out to the truck and basically made sure all the wiring harnesses were secure. Nothing seemed to be loose, nothing seemed to move but guess what ..... Truck is running fine now. 2 days running no problems. wanted to make sure it wasnt a fluke before posting this but seems to be fine.
Old 09-09-2005, 10:15 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
timing, unplug the brown and black timing wire from the ECM under the glove box and set the timing with a timing gun to o degrees.
Also, what did you tuneup include?
1995 Factory Blazer Service Manual for sale, PM if interested.
