Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-27-2005, 12:52 AM
Stealth_SUX_ Stealth_SUX_ is offline
power steering
Is there a way of disabling the power steering without taking the belt off. Also if i do take the belt off will it mess up anything, besides not having a/c or power steering. Also how hard is it to put the belt back on, a description on how to put a belt on would be great to, pictures would even be better. Thanks
Old 08-27-2005, 10:17 AM
99 Neon R/T 99 Neon R/T is offline
Re: power steering
I think pulling the belt is your only option.There is a bolt behind the power steering pump that will let the pump swivel down enough to remove the belt.The bolt is a 13mm and a racheting wrench will save you some agrivation.I am sorry I cant be more help than that.I havent seen my car in over a year because I am deployed in Iraq so I am a little rusty on the exact stuff
Old 08-27-2005, 02:03 PM
Re: Re: power steering
Cool that is helpful, would u put the belt on the same way, by loosening the bolt
Old 08-28-2005, 09:29 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Re: Re: power steering
Yes! Why do you want to disable your power steering? Just taking the belt off makes the car harder to turn, than if you remove the P/S system. If you remove the whole system, it is much easier to turn.
Old 08-28-2005, 11:35 AM
Re: power steering
I think he is just looking for a little hp once in a while.
Old 08-28-2005, 12:17 PM
yep just wanted to add a few cheap hp
Old 08-28-2005, 06:42 PM
Then remove the whole system and lose some extra weight while you're at it. Like I said before the car is hard to steer with just the P/S belt removed, but is much nicer with the system removed. The only place you might miss it, is during parallel parking!
Old 08-28-2005, 11:59 PM
palindromelol palindromelol is offline
Re: power steering
I disabled mine by allowing the HP side fluid line to wear through the LP side fluid line. Unplanned power steering loss nice.....The two tubes are darn close to one another.
