Old 08-26-2005, 07:21 PM
kbock kbock is offline
battery light
This is a little confusing some one might be able to help. the battery light in our 1996 cavalier comes on after 35mph and kicks off when we hit 68mph. It dosn't always come on driving it the city but always on the highway. Any answers? Oh we've had the battery checked and each time is fine also put in new alternater awhile back that shoots checking the battery again.
Old 08-28-2005, 12:22 AM
Chekmate Chekmate is offline
Does it do this between the speeds or between a certain RPM range?
Id recommend checking your electrical connections to/from alternator. As well as your battery terminal connections, make sure they are all tight and free of corrosion. Normally a alternator should be charging around 13-14.7 volts, if you have a DVOM you could check it. Have you had your alternator load tested, most auto parts stores can do it for free around here. Hope that helps.
Old 08-30-2005, 03:17 PM
RonBurgendy RonBurgendy is offline
Re: battery light
I work at our local advance and i see people coming in with that problem all the time. and it is confusing but 9 times out of 10 it's a bad connection. clean your terminals real well and make sure the wires are tight. just like checkmate said. he was right there. that really should solve your problem
Old 09-10-2005, 11:38 AM
freakinsick freakinsick is offline
Re: Re: battery light
oh man so you got the hookups?
