Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-26-2005, 05:56 PM
rb1921 rb1921 is offline
1991 camry warning lights on
Hello
I have a 1991 Camry LE, today, the Charge light, brake light, and headlight lights lit up on my dashboard, I took the car and had the battery tested they said its fine, the alternator is only 2-3months old, I went to ge the oil change becuz i needed to anyway and they said the fuel valve gasket was leaking oil , would this kick on those lights, or do I have another problem altogether. the car seems to be running fine, but I commute and I dont want to be stranded on the highway, the check engine and check oil lights have not kicked on yet. Thanks for any help in advance
Old 08-26-2005, 09:16 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Normally what you experiance happens with an alt is not charging correctly (It's bad). I would start by replacing that alt under whatever warrenty it came with.
A leaking valve cover has nothing to do with anything electrical/mechanical. Don't worry about it until you get tired of the burning oil smell.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
