Old 08-26-2005, 02:13 PM
CAMCAMI CAMCAMI is offline
Transmission
at 114,000 miles seems as though my auto. transmission is slipping... when in drive, i press on the gas and it hessitates before it takes off... it does that until i hit about 35mph... i got my transmission flushed but there is still the problem... i have to take off in 1st, then 2nd, & 3rd then to drive... oh!!!.. i also have the injetors changes cause they were hecka clogged....can anyone advise me as to what to do???
Old 08-27-2005, 03:34 PM
PotIsYourFriend PotIsYourFriend is offline
Re: Transmission
You've only flushed it? You might want to change the filter as well. I've done it myself twice and I have 120k miles.. It's a piece of cake... Just jack the car up take out all the bolts and pull the pan off.. Pull the filter off, take the new filter and remove the plug over the female end and puch it into place and bolt the pan back on and add how ever many Qts it says to add.. Since the car was made with no f*cking dipstick by a dipsh*t company...
Old 08-30-2005, 11:42 AM
Re: Transmission
thanks for the response... soo you had the same problem... and after you changed the filter you did not have the hesitation problem anymore???
Old 08-30-2005, 05:27 PM
Re: Transmission
Well I had the problem like you but it was the fuel filter being partially clogged (I had never changed my fuel filter until I had to replace the fuel pump which cost around 700 bucks...)
