Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 08-26-2005, 03:00 PM
71chaz 71chaz is offline
need help replacing belt tensioner - 95 skylark
The belt tensioner on my 95 Skylark needs to be replaced...it could come loose at any time. My question is...how involved is replacing the belt tensioner? I would like to do it myself to save some $$$. Any suggestions on how to remove and install the part? Thanks!
Old 08-26-2005, 03:40 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: need help replacing belt tensioner - 95 skylark
have you got the 3800 engine? I doubt you do. It should be the same for the 3.1 and 3.4 engines.
you'll need a metric set of sockets
socket wrench
12 pack of bud(optional)
take your socket wrench and use a 15mm socket(I think) to release ension on the belt, and remove the belt. Take care to remember which way the belt sat in the engine, and the path it takes. its important to keep a belt spinning the same way all its life.
use a 15mm socket(i think) and remove the 2 power steering pump bolts.the socket should with through the openings in the PS pully
set the ps pump aside, no need to disconnect the ps lines. you should have access to all the bolts to take the tensioner unit off.
repeat backards to install. beer may be consumed at anytime
Old 08-26-2005, 04:05 PM
I have the 3.1 engine...thanks for the info...
Any idea how many bolts hold the tensioner unit in place?
Old 08-26-2005, 04:12 PM
tman's Avatar
Pimpin' ain't easy
Not sure, I'd guess 5-10, you should be able to see all of them though
Old 09-21-2005, 08:03 AM
Ultralight Ultralight is offline
Been there done that. There is one bolt in the middle but the kicker is getting to it. I had to remove my wheel and the inner fender well to get to it. My problem was that the plastic around the bolt was broken and the whole tensioner was sitting sideways so it was a pain getting a wrench or scoket on it. Hopefully you won`t have that much trouble. Hope this helps.
Ultralight
