Old 08-26-2005, 01:13 PM
lftdblksilvy33 lftdblksilvy33 is offline
cold air intakes
i recently got my truck lifted, and im wanted to get some of my power back. i have a 4.8 2001 silverado. i was wondering which air intake you guys would recommend.
Old 08-26-2005, 10:45 PM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
Re: cold air intakes
from what I see here, the K&N FIPK GENII kits are the rage. CHeck ebay for best prices.
Old 08-27-2005, 12:44 AM
Rollingbones's Avatar
Rollingbones Rollingbones is offline
I'm kinda partial to this set up. [url]
http://files.automotiveforums.com/ga...sort=1&cat=500
I've really not heard anything bad about any of them. Some will keep the box with the idea it picks up less hot air from the engine while others (suck as myself) believe they're more restrictive in air flow. I got my FIPK GenII on eBay for about $205 delivered and it only took about 45 minutes to install (easy). It also allows you to use your stock mass air flow sensor. The system is really well built. After you install it, it'll take a couple of short trips for the computer to dial it in, but that'll happen fast. When I first put mine in, it sputtered the first trip around the block. By the next day it was smok'n
2002 Superado, LT (Carmine Red), 5.3 L
3.73 RR, Flowmaster, K&N FIPK Cold Air Intake,
160 T-stat, Hypertech Tune, Towing Pkg.
More pics here: http://www.cardomain.com/ride/2091584
HAVE A NICE DAY...
...Unless you have other plans!!!
Old 08-27-2005, 12:47 AM
Let's try that link again!!!
Old 08-27-2005, 01:42 AM
jers99z jers99z is offline
Send a message via AIM to jers99z Send a message via MSN to jers99z Send a message via Yahoo to jers99z
I myself weighed out pros and cons, My major concern was for when I take the truck out and go off roading, the K&N is a good system in my opinion for a street truck, it will give you good performance but the draw back to me is the open element airfilter. I chose the Volant because of the enclosed box design and the performace numbers they had posted. And if you wanted to add a little more oomph, they offer a ram air pipe. Well to get to the point, I went with the volant to reduce my chances of sucking up water and clogging the filter with mud. Well good luck with choosing.
Old 08-27-2005, 03:13 AM
Like I said, it's baker's choice. I don't plan to go off road so I like the total air access. You can realy hear the air being sucked in. Since it's basically where the box would be (IE fairly well protected), I'm not too concerned about rain and such and I haven't heard any complaints in that department from anyone else. I can see where the box would be desirable for off roading.
Old 08-28-2005, 09:13 AM
sreve sreve is offline
i assume you put larger tires on in addition to the lift? if so that raised your final gear ratio. that will reduce low speed uummp. reprograming for the tires wiill help.
Old 08-28-2005, 03:22 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
i bought a generic setup on ebay for about 50 bucks and doesnt seem much different than my buddy's k&n setup except i paid 200 less. there are pics in my sig click the link.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
