Old 08-26-2005, 12:16 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Normal Vac at idle
Ok got a question, what is the normal amount of Vac. i should see at idel (800-1k)
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 12:42 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Normal Vac at idle
17-19hg
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-26-2005, 12:49 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Depends on what the elevation is where you live. @ sea-level it should be 14-15. I see about 12 at idel because I'm 1780 above sea-level. I see 15 when I let off the gas while crusing.
DSM geek
Old 08-26-2005, 01:03 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I get 18 in/hg @ idle and about 22 - 23 in/hg during deceleration.
Scottse, your's seems a little low, are you sure you don't have a vacuum leak?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-26-2005, 01:16 PM
Not sure in the slightest. I always figured Vac reflected Appsolute pressure. Im starting to second guess now. Durring Idel their is no possitive pressure, so the engine is running on air pressure to get air through the valves & into the cylinder durring overlap. Am i missing somthing? I know that exhaust gas causes a small draft like effect helping air into the cylinder. I didn't think it helped anywhere near that much! Humm. Crap. Another problem!
DSM geek
Old 08-26-2005, 01:25 PM
-Josh-'s Avatar
Yeah scotsee, that's a little to low for vacuum.
AF User Guidelines
Old 08-26-2005, 04:17 PM
i live in louisiana and im getting 10-13 at 1k idle and decel is like 18-19
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 06:27 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
with 3" turbo back, i get like 21 at idol and decel is 30 or so...im in VA tho
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 08-26-2005, 08:10 PM
ok well fixed a few leaks. one big leak. Thought i had it whooped. Started car, still only reads 10-12 vac at idle and 19 at decel. I dont know peps.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 08:21 PM
ok one more thing. i pressured my system to 10psi,on my joe p boost controler, you know the little hole in the controller itself, well it was leaking from there. but when i run it, it boost up to 14psi, should it be leaking at that point or what. just a question, not quit sure.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-27-2005, 05:33 AM
kjewer1 kjewer1 is offline
AF - Advisor
In my very limited experience with these cars, normal vacuum on stock cams is 19-22", with 264s its 14-15", and with 272s its 10-12", IIRC.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-27-2005, 07:46 AM
well wtf, i nknow i still have stock cams. i dont know why its only doing 10-12vac any ideas?
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-27-2005, 08:56 AM
could the gauge be messed up at reading vac, what about that hole in the Joe P boost controller? this SUCKS
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-28-2005, 02:06 AM
AF - Advisor
Could be vac leak after the throttle body, leak to the guage, or a shite guage. Then you get into the complicated things like timing off a tooth, etc .
Kevin Jewer
Old 08-28-2005, 07:42 AM
im also having misfires, wouldnt that be cause by timing off a tooth?
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
