Originally Posted by Bads Crew
Have you changed the cap and rotor? Put a plug on the wire and hold the plug to a ground or use a jumper cable and clip the plug with one end of the cable and the other to a good groung on the block. Have someone turn it over while you see if the plug has spark. If you don't have spark I will try to tell how to check the compression corectly.
If you have a cracked cap you can burn a valve. AT 150 psi it sounds like you have compression. Leaky intake, Maybe. Did you run a compression test on the other cylinders? The minimum compression should not be less than 70% of the highest. A leaky intake will not make you loose compresion but would effect fuel to that cylinder. Have you pulled the rocker cover to see if a rocker has broke or come off?
