Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 08-26-2005, 11:13 AM
shametrain shametrain is offline
after market air intake
i bought a k&n air intake on ebay-makes car sound mean but completely messes with the oxygen sensers-service engine light come on and tranny delays shifting.anyone put an after market intake on and made it work-it does make the car growl when it works!!--thanks
Old 09-02-2005, 01:05 PM
ctesla's Avatar
ctesla ctesla is offline
the air flow has been changed, so the air/fuel mix going into the combustion chamber is different, probably creating a lean condition.
try unplugging the fuel pump and/or injector relays for about 10-15 minutes; or you could just disconnect the POS(+) battery cable for a couple of minutes (if you do this, ensure you have the radio code (if still factory stereo), otherwise it will LOCk out, preventing operation; if you do not have the radio code, you can leave the ignition key in the ON position (with the vehicle OFF), while disconnecting the battery, and the radio won't lock out) to clear the ECM(computer) and allowing it to re-think and re-program for a different air intake system.
you also might take some air intake cleaner, and spray (sparingly) into the intake horn and clean off the MassAirFlow sensor.
the "weather vane" type filament in the air stream is highly suseptible to humidity, and "non"-air products (like the oil from a K&N filter), and might be just slightly dirty, also causing an engine light, and idle/surging problems.
hope this helps,
chris
nrt racing
Old 09-02-2005, 02:50 PM
Re: after market air intake
hope this helps,
chris
nrt racing
great information- thanks chris
