Old 08-26-2005, 09:54 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
safc2 installed have one question
I installed the safc2 and everything seems to be up to par. Now, the knock meter jumps around a lot. It reads a lot like this: 5, 10, 18, 9, 20, 9, 12, etc. Its very random. Is this normal? I was under the impression it would stay constant, but more and more i think about it, it may makes sense it jumps around because the engine is never really constant. Please let me know. thanks guys! Ray
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 08-26-2005, 10:24 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: safc2 installed have one question
You can't read knock on a 2g with the SAFC-II. What you are seeing is garbage. I would unhook the wire.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-26-2005, 12:13 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Re: Re: safc2 installed have one question
yea only 1gs will read knock. just unhook the knock sensor wire.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 03:32 PM
damn that sux....I cant read it with my pocketlogger also...
My Car
Old 08-26-2005, 04:15 PM
yea us 2g owners have to do it the hard way
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 07:09 PM
99eclipsegst 99eclipsegst is offline
What would the hard way be...? For future reference.
1999 Eclipse GST
Mod List: T-25, greddy boost controller, k&N intake, Apex'i Exhaust, Boost Gauge, Greddy BOV, Greddy IC Piping, Dump Tube Mod, Symborski Shifter Kit, B&M Short Throw Shifter, Turbo Timer, and Apex'i DP.
Future Mods: Evo III with supporting mods in 2-3 months .
[IMG][/IMG][IMG][img]
Old 08-26-2005, 08:09 PM
we have to use the STFT and LTFT and timing and use that to know when we getting knock. 1g just adjust till the knock sensor say no more knock and then run.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 08-26-2005, 10:27 PM
I dont understand though. When you look at the pin layout for the ecu, there is a pin for knock. Even in the safc2 install instructions and prostreetonline.com says to tap into this wire.
oh and 95eclipse gst, you wouldnt happen to a write up or tech article on stft and ltft and timing would you? Im a newbie tuner and have no idea what im doing. thanks man!
My Car
Old 08-27-2005, 05:30 AM
kjewer1 kjewer1 is offline
AF - Advisor
DSM knock sensors are not compatible with the AFC. I heard on this forum I believe that there is a bosch sensor that can be read properly by the AFC however. Otherwise, do it "the hard way" as mentioned, or with DSMlink.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-27-2005, 10:50 AM
Sometimes I think youre a spokeperson for dsmlink, Kevin. You are always trying to sell me dsmlink and everytime i get more and more tempted to go with that setup.
Where can i get this bosch sensor at? How does it work? Id really hate do it the hard way. If anyone have any info please let me know.
btw, my friend just got a 95 gsx and he gave me his ecu. Im assuming this an eprom ecu, right?
My Car
Old 08-28-2005, 02:00 AM
AF - Advisor
You would have to open it up to check. Later 95s were not eprom. www.tmo.com has instructions for how to tell if its an eprom or not.
Kevin Jewer
