Old 08-26-2005, 06:04 AM
Jere_RB Jere_RB is offline
Transplanting parts from a 90 grand am to a 94
I found a 90 model grand am at a local junkyard. The parts I need from it are the radiator and the dashboard (after painting the dash to match my old one, that is). However, I don't know if these parts will fit my current vehicle. Does anyone know if the radiator and dash board from this junked 90 grand am will fit my 94?
Old 08-26-2005, 10:42 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Transplanting parts from a 90 grand am to a 94
Welcome Jere_RB ! The radiator from the 90 might work in ur 94. Just measure the radiators length and width and hieght, if they match it should work, also the hose connections must be the same. I would like to Caution YOU, look at the radi. from the Yard, do u see any thing that looks like cracks in the plastic side-caps? over time due to heat(expansion) and cold(contract) they start to crack and eventually burst and thats no good.
When you say dash are u talking about the gauge cluster or the Top part of the dash?
I'm not sure on that but keep checkin back surely someone knows for certian. the body styles are a close match? Cant picture them right off....
Old 08-26-2005, 06:55 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It's doubtful that any of the dash parts will fit your 94, the cars are physically different widths and lengths as the body was completely reworked in 1992. As for the radiator, follow what xero said, measure it and check it carefully as they do crack, usually on the driver's side first as that side does get hotter faster, thus going through more extreme changes in temp.
