Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 08-26-2005, 04:06 AM
mr_hops48 mr_hops48 is offline
2000 cougar blower motor
I lost the 3 low speeds on the blower motor today. only the #4 setting
(high) works. any ideas on where to start looking? the fan was running
at setting 2 and just died. i opened the hood to see if i could see the blower motor and all i can say is wow.. it that thing packed tight. might the resistor be under dash?
Old 08-26-2005, 03:20 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
the blower motor resistor is defienetly your problem, and yes, its in the dash, somewhere, i can imagine youll wanna do this on a day when you have ALOT of time and patience
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-28-2005, 04:49 PM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
The blower motor is above the passenger's foot compartment, it just twists like 10 degrees counterclockwise to be removed, but it's not you problem, the resistor is about 8 inches toward the drivers side and there is a 4 wire (i think) plugin and it plug straight toward the front. I think it's held in by 2 8mm head screws. Call your dealer though, there is a recall for that same problem on '99 models and I'd bet 2000 also. The resistor melts down and the dealer should fix it for free.
Old 08-28-2005, 09:35 PM
thank you
thanks for all the info !
