Old 08-26-2005, 03:13 AM
Backfire55 Backfire55 is offline
Question Flipping Air Cleaner Lid
I've heard that if you flip your air cleaner lid upside down it increases your vehicles performance slightly. I'm just wondering if anybody has tried this and if it did actually make any difference? Also, has anybody tried the K&N X-Stream Air cleaner lid?... and what did they think of it?
Old 08-28-2005, 06:41 PM
waterboy1381 waterboy1381 is offline
Send a message via AIM to waterboy1381 Send a message via Yahoo to waterboy1381
lid flip?...
While I have never heard of getting an air cleaner flip and gaining any performance i have heard of other options. If you have a light truck where the cleaner is not on top of the heads to create the look of a carbeurated motor it will be down, away from the motor. If it is like this you can simply cut away the section of the plastic box facing away from the motor to bring in more and colder air. If it is on top of the block, I suggest creating your own ram air system if your willing to do it. Simply get a large enough hood scoop to bring in enough air and mold it in, not just tape it. With the scoop there permanently you want to cut a hole in the bottom of your hood under the hood scoop (hole will be unnoticable on a closed hood). This will bring air through the scoop to the top of your air filter. From there, remove your metal box from around the filter and get an old muscle car type filter with a metal cap over top (this cap will keep dirty air from getting into manifold) and fabricate a few mini bars if needed to keep it in place. Good luck and I hope you get the performance you desire.
-Jut-
Old 09-26-2005, 04:23 PM
jbragg jbragg is offline
it give better airflow
flipping your air cleanere lid over does give a noticeable change atleast it did for my 4.3 only thing is if you do this i recomend buying a k&n air filter or a cool blue atleast a cleanable air filter
Old 10-04-2005, 08:55 AM
'94F-150 '94F-150 is offline
Re: Flipping Air Cleaner Lid
Flipping the air cleaner lid really does give a boost, at least on my '86 chevy pickup. But you need to be careful about going through mud or sand or places where dirt may get on the filter. If just drive on the street your probably ok, but just watch out about going off road.
