Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-26-2005, 12:18 AM
hondaguy209 hondaguy209 is offline
vac boost guage problem
like the title says the vac boost guage does not work on my aunt 94 thunder bird sc. I wanted to know if any body has had this problem before, if not were is the stock sensor located. thanks in advantced.
Old 08-26-2005, 11:25 AM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: vac boost guage problem
a vaccum hose/line is probably become disconnected..
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 08-27-2005, 07:31 PM
Iv look at the engine and so far i havent seen anything loose or disconnect. Were would the vacumme line for the boost guage be located.
Old 08-29-2005, 12:17 AM
coondawg6 coondawg6 is offline
if your underhood stickers are still intact theres a vacuum diagram on one of them if not autozone can get you a diagram
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 08-29-2005, 05:10 PM
thanks ill try that tonight and ill get back to you guys. thanks agin.
Old 09-07-2005, 10:19 PM
Ihad fixed it the other day tuns out the vac line on the back of the manifold coming from the intercooler had become brittle from heat and broke off.Thank for all the help.
