Go Back   Automotive Forums Car Chat > Eagle > General Discussion
Old 08-26-2005, 12:12 AM
xsboost xsboost is offline
need help
well i just put a water pump on my 92 talon tsi awd and i put it all together the right way even the timing belt and it wont start now so i dont know what to do?
Old 08-30-2005, 01:39 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: need help
go back and make sure your teeth on that belt are properly lined up. Just so you know next time you do this kind of job and have to take off the timing belt, you must index the timing belt. What that does, it keeps the alignment of the belt in place, unless you're replacing the belt altogether, that step is not necessary. Make sure also, that your belt tensioner is tight against the belt and also that you have the proper tension on that timing belt. Timing belts require a lot of tension than normal drive belts. A loose belt can cause a gear to skip a tooth and have you in the situation that you are in now.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
