Old 08-25-2005, 07:55 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Got my FMIC have questions before install
Okay i just my fmic today and now im ready to install before i go back to school. I just have two questions.
1. How long does this process take if its your first time?
2. The really bad install instructions says i have to cut the plastic cover vent. Dont i also need to cut the fiberglass bumper as well? thanks guys in advance.....
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 08-25-2005, 08:34 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Got my FMIC have questions before install
Did you just get the fmic or did you get the piping too? Depending on the size you might have to cut the fiberglass bumper.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-25-2005, 08:36 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
depends on size of intercooler, is piping included? and etc. Mine took about 2 hours the first time and then a bunch of re-fittings after that. Took so long really because of homemade piping but if it is premade your set.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 08-25-2005, 09:04 PM
This is the specs...Length 31" (600mm)
Height 11" (280mm)
Thickness 3" (75mm)
The piping is homemade but done for me to fit the IC
My Car
Old 08-25-2005, 09:16 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
If your pipes are allready made. Taking the head lights and front bumper for the first time can be an experence. Then mounting the intercooler could be intresting as well if there are no brackets or mounting supplys. Getting the pipes to fit is pretty easy if you made the right messurments.
Test fitting your bumper where you'll want to be carefull, cutting bumpers is a little numbing. Can't go back and do it agian if you mess up.
I'd say on a first time install. Give yourself at least 9 hours.
DSM geek
Old 08-25-2005, 11:32 PM
Now exactly what do you cut it with? And what do you cut? Do you cut the actual bumper or that white bumper piece?
My Car
Old 08-27-2005, 10:52 AM
What did you guys use to cut the black piece offf of the bumper? Did you guys like make measurments not to fuck up? Im scared that i will make it uneven. For those of you who are unclear, its the black piece that sits right under the diamond and under the license plate.
My Car
Old 08-27-2005, 10:57 AM
use tape to make your lines. Use dremmel if you dont have an cutting tool & air compressor.
DSM geek
