front end clicking
at low speeds there is a clicking sounds like its coming from the passenger side, possibly ball joints i don't know. Its more noticable when hitting a bump on that side or when turning left
Does it only make the clicking when going overa bump or does it do it when driving at low speeds. Could be a CV Joint a U Joint or a differential noise.If it only happens when you hit a bump could be a ball joint tie rod steering stablizer that is broke or a shock. probally have to Jack up the front end with the wheels off the ground and turn the wheels by hand and see if you csn tell where the noise is comming from.
If nothing place some jack stands under the Jeep and have a good look around. |
Re: front end clicking
i can put it on a hoist, but i guess i should have specified i can't hear the noise once i get around 20mph and its just more noticable when hitting a bump, but yeah i guess i'll have to look around thanks for the help
If the hoist is one that has the tires free, try turning the front wheels in neutral. Sometimes the CV joint will make a clicking and the side gear in the Diff at low speeds.
