Old 08-25-2005, 03:16 PM
NSPremier NSPremier is offline
Electric Fan Question
My electric fan does not turn on as engine heats up or a/c switched on. The fan itself works (I hot wired to the batt momentarily to test). I followed the wiring over to the driver side fender and then it goes in to a big cluster of wiring. Is there a fuse or junction that is a likely problem here?
Also. If I were to just hardwire a switch to the dash for manual control what fuse rating should I use to protect the circuit?
Thanks
J
Old 08-25-2005, 05:58 PM
bayouwolf's Avatar
bayouwolf bayouwolf is offline
First of all...
Welcome to AF
Now on to the question at hand.
Depends on the year/ motor, In My 97' the fan is wired to a temp sensor. It only switches on when the sensor reaches a predetermined level ( like 200 or 210) or when you are sitting at a stop light. It's probably a bad sensor. Just a plug and play type device, Very D.I.Y.. As far as wiring it to a switch, I did the same thing in mine ( for water fording ) and I started with a 15 amp. It probably could be less but I'd hate for it to blow on the trail. The only problem I have is that I would forget to turn it on at traffic lights and the temp would soar! I ended up wiring it inline with the sensor. I can shut it off if it runs on its own while I'm bumping around the woods, but it's still controlled by the sensor during normal driving.
It's all fun and games till' someone gets banned. Then its fricken hilarious!
Old 08-25-2005, 08:50 PM
89ltd 89ltd is offline
Re: Electric Fan Question
some have a fusable link from the starter relay and leading to the electric fan relay. It could be either the temp sensor , relay, fuse link, depending on the year and engine.....
