Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 08-25-2005, 02:31 PM
t_fuNk t_fuNk is offline
Send a message via AIM to t_fuNk Send a message via MSN to t_fuNk
problem with vtec
Hey everyone. I just recently bought a 94 Honda Civic del Sol Si.While on a trip, the VTEC seemed to have over heated. I was cruising around 75 in fifth gear, right around VTEC initialization. I had it on cruise control. It turned off after about fifty miles. I slowed to the shoulder. I cranked it and it worked fine, but while merging, I hit VTEC and it turned off. I drove it there under VTEC. After a few hours, VTEC was working fine. I haven't had any more problems with that. Does anyone know what could have happened or if it caused any permanent damage?
"I hope if dogs ever take over the world and they choose a king,
they don't just go by size, because I bet there are some Chihuahuas
with some good ideas." -Jack Handey
Old 08-25-2005, 02:57 PM
ImSoYesterday ImSoYesterday is offline
Send a message via ICQ to ImSoYesterday Send a message via AIM to ImSoYesterday Send a message via MSN to ImSoYesterday Send a message via Yahoo to ImSoYesterday
In order to know anything about your problem you must understand VTEC technology.
VTEC stands for Variable valve Timing and life Electronic Control.
The VTEC is a method to optimize air/fuel mixture flow through the engine.
There are ways to make your engine produce more power, forced induction (compressing air-fuel more greatly in cylinders). Higher displacement, speaks for itself, the difference between a 1.6 and a 1.8... Well what Honda has done is just made everything move faster, to increase power. But this is for high speeds, and most of us with our VTEC engines dont spend our whole life redlining, is why Honda implemented VTEC. Basically at XXXX RPM Your VTEC will 'activate' and your valves will open wider, and when you are cruising the lower RPMs your valves will not be open as wide as they are when your VTEC 'activates'
What happens is the engines computer activates alternate lobes at a certain RPM to change the cam timing and valve overlap.
This will not make sence to you unless yhou understand a combustion cycle however.
In result there is a million thigns that could have been wrong, with your cam,valves, lobes, or most likely electrical. Has the car seen any unordinary acts that would f-up the ECU?
Emily's personal boyslave
TSS: Rockin' the Bitches' Faces.
B16A2 engine with:
Short ram intake.
DC Sport header: Ceramic coated, 4-2-1.
Custom headerback exhaust with disconnected muffler.
MSD Ignition system. (With Enkei wires)
http://www.cardomain.com/id/imsoyesterday
Old 08-25-2005, 08:24 PM
Re: problem with vtec
I beleive I understand what VTEC is, I was just asking what could have happened. Before, the tach had been jumping around when I hit VTEC. I dont know if these incidents are related. Thank you for any suggestions.
Old 08-25-2005, 09:47 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Ok i am not trying to be a smartass, but maybe you need a lesson on VTEC operation yourself. First off, What do you mean by Honda has made everything move faster to increase power. Makes no sense to me. Valves dont open wider, that is simply impossible. They are held open longer (more duration) and open at a higher lift. (meaning, that they are pushed further way from their seat) Maybe you meant wide as in higher lift, but you forgot to mention duration. And the computer does not activate any "lobes". There is no lobe activation in VTEC. The computer reads the Map sensor, ECT sensor, TPS sensor, and engine speed to decide when to activate the "VTEC Solenoid". The VTEC solenoid then moves the spool valve which in turn engages the third rocker arm (the middle one on DOHC models), via hydrolic pressure, or engine oil pressure to be exact. When the third rocker arm is engaged, the Valves are forced to follow the cam profile of the VTEC lobe. When not engaged, The VTEC rocker arm "floats", not having any effect on the other valves. VTEC is essentially like throwing a set of high lift high duration cams in the engine when it engages, except, you don't have to suffer low RPM operation when not engaged. I hope this was informing, as i am tired of typing now
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 08-26-2005, 01:59 PM
I am going by the research I had done for a school project, and with the cam/lobe setup I knew to be true with DOHC motors. All of my knowlege is based off of what I researched back in school, I haven't got to take it apart yet...
B16A2 engine with:
Short ram intake.
Old 08-28-2005, 09:58 PM
Well thanks for the information on VTEC guys. To get back to my original question, does anyone know if cruising right around the speed/RPM at which VTEC engages potentially make the solenoid engage and disengage so as to "break" or just over heat the solenoid? Has anyone else ever experienced this?
Old 08-30-2005, 01:38 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
people who complain about their vtec not working or "just cant feel the vtec," are just plain paranoid. if your the oil pressure or selenoid is not operating correctly your ecu will throw a CEL. its that simple.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 08-30-2005, 05:23 PM
Well.. I don't beleive I'm paranoid about VTEC. If no one can understand what I am asking, then don't worry about it. I'll ask someone else that knows something, thanks anyway.
Old 08-31-2005, 03:07 AM
AF - Advisor
dont take it so rough. too many new folks here are too sensative. the post should tell you that it is not vtec related.
as far as your car dieing, it can be anything from your description. tps, map, compression, dizzy, vac leaks, no fuel, vss, ecu to name a few.
good luck.
Old 08-31-2005, 10:37 AM
flameboy79 flameboy79 is offline
Don't none of you guys know about reading fault codes?
Even if your car is not throwing the CEL light automatically, there can still be a fault logged on the ECU. So when in the situation that you are in it is where I would start.
In the passenger footwell is your ECU. Bundled by the ECU will be some service connectors. You want the small two pin one. It may be housed in some rubber casing, if so just pull it out. Bridge it with something like a paperclip, turn the keys (but don't start engine) and watch the ECU cel light.
If it stays on then no problems. If it flashes then count the flashes. A long flash is 10 and a short flash is one. So... long, long, long, long, short would be fault code 41. Do a google search for Honda fault codes and compare.
There is a fault code for faulty VTEC solenoid so if that is the problem it should in theory show up.
