Old 08-25-2005, 03:16 PM
chigger23 chigger23 is offline
98 LT 4WD Vibration in Floor all the time
Slight Vibration when ever the car is running.
Vibrates in nuetrual. park , drive and reverse.
Kind of feels as if exasht may not be tight enough? Maybe motor Mounts?
Think that I had hear that they made some sort of special colar for where the Exausht comes out of the engnine due to excessive noise on this model.
Anyone else have this.
Remember it happens even when on and parked not a drivablity issue.
TALK TO ME GOOSE!!!!!!!!!!!!!!!!!!
Old 08-28-2005, 12:01 AM
Re: 98 LT 4WD Vibration in Floor all the time
COME ON I CAN NOT BE THE ONLY PERSON WITH THIS< YOU KNOW WHO YOU ARE!!!!!!!!!!!!!!!!!!!!!!!
Old 08-29-2005, 11:54 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Have you done a tuneup? Your engine could be missing.
Other than that, check your motor and tranny mounts.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-29-2005, 01:11 PM
Re: Re: 98 LT 4WD Vibration in Floor all the time
Checkjed this morning and the engine was definatley there, not missing, just kidding. Engine sounds good, will have them check the mounts.
Old 08-29-2005, 05:56 PM
BlazerLT's Avatar
AF -Advisor
How long ago have you tuned it up?
Old 08-29-2005, 11:47 PM
Well here is the thing, it has 122K Miles on it, but... at 92K the Head Gasket Shit the bed, didnt realize that was why my antifreeze slowing being used up, long story short GM paid to rebuild the whole top half of the engine. Everything on the top of the engine was redone or replaced. So, I gueese when they put it back together they would have had to have done the equivlant of a tune up. Had the Fuel Filter done I know at 60K.
What exactly on this car do they need to tune up> ?
Old 08-30-2005, 11:06 AM
BlazerLT's Avatar
AF -Advisor
What you need to tuneup is:
Fuel filter
Spark plugs AC Delco Platinum only
Cap & Rotor
Air Filter
PCV Valve
Transission flush and refill and a new filter
Differential fluid and transfer case fluid change
You need to stop assuming everything is ok with the tune. Something has to be causing the shaking and I can bet in part it is due to it needing a tuneup and possibly your motor or tranny mounts being shot.
Your fuel filter alone should be changed every 30k.
Old 08-31-2005, 01:59 PM
Fuel filter
Cap & Rotor
Air Filter
PCV Valve
Can you tell me where to fine the fuel filter on the 98 and if it is as simple as changeing the oil, I assume that there are cut off vavles between the filter and gas tank, as well as filter and engine.
Old 08-31-2005, 03:21 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
No cut off valves. Take the filter off, have some catch rags handy to sop up the slow escape of gas from the lines as they drain. NO SMOKING! I am a smoker and when it's time to take a break, I make sure to pull off the work shirt, gloves and light up a good 20 paces upwind from the rig when working on it. I've seen car batteries explode right under the hand some fool was holding a lit cigarette in when he went to go get a look at something under the hood. *POP* <<sizzle>> "Someone call 911!" Entire left side of the man's face, arm, torso and leg is still gnarled and scarred. Be especially careful around flammables, have a buddy watching your back with a fire extinguisher when dealing with fuel.
