Security System Problem
I have read a couple of the security issues that others are having with their Jeeps. I have a 95 Grand Cherokee Limited and ever since it was fixed from an accident, the alarm decides when it is going to go off. It only happens when the jeep is locked and happens so randomly. The only way I seem to be able to keep the alarm from sounding when the car is locked is if fuse 6 and 7 are pulled out. It is a pain to pull these out and put them back in every time I lock and before I start the car. Is there anything that I can do or a wire that I can cut that will make this madness stop? I have taken it back to the repair shop and they said that they don't see a problem.
Re: Security System Problem
OBVIOUSLY A POSSIBLE WORK AROUND, DOSENT CURE THE FAULT.
CABMAN |
try unplugging the hood switch in the engine compartment (passengerside, on the hood rail). leave it unplugged for a few days to see if it happens anymore. these switches alwyas get messed with and when the wind blows it will move the hoo enough to ground the connection and make the security system thing it is being tampered with.
Re: Re: Security System Problem
No the problem proabably won't go away. What you will need to do is get a new switch because it is wore out and not being pushed down enough to disengage or you could glue something onto the plastic block that is on the hood itself which pushes the button down. Glue something about 1/4' thick onto it so it iwll push the button down and keep it down.
