Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-25-2005, 01:23 PM
bayouplayer bayouplayer is offline
2001 Monte Carlo Electrical Problems
I've been having this problem for about 6 months now and no one has an ideal on how to fix it. My battery indicator is always high. Once night falls, it goes into the red as an alarm. This also causes my turn signal to not work from time to time. Also my headlights will not come on or they will go out while driving. I've tested the battery, replace the signal/wipe switch, and I've replaced the dash cluster. Does anyone has any ideal what the problem might be?
Old 08-25-2005, 04:38 PM
montecarlossfan montecarlossfan is offline
well my guess is that your alternator is on its way out, or has a bad voltage regulator..since most of the power is used at night...try this...turn on ur a/c , headlights, hazards, radio, wipers etc and see what the needle does..it should drop..if its the alternator
Old 09-01-2005, 04:46 PM
I tried that but the indicator didn't move, it's still to the max. I got the alternator tested and it's ok. what else could it be?
Old 09-02-2005, 01:27 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 2001 Monte Carlo Electrical Problems
Have the battery load tested, and retighten all battery terminals and the terminal on the back of the alternator. Also, try to track down the ground wire from the battery to the engine. Check for damage retighten if necessary.
