Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 08-25-2005, 01:21 PM
King Of Crunk's Avatar
King Of Crunk King Of Crunk is offline
Angry Project Super Sleeper
Okay well I'm starting to look for a new car and i've decided to go with a super sleeper that i plan on modding the hell out of....i want one of those cars that you just look at and shrug off and then when they go WOT, you're confused on how a family sedan could go that fast...i'm not planning on spending more than 15k on the car....and i've narrowed it down to these:
1. 2000 Pontiac GTP (i would debadge this and take off any spoilers etc....make it look like a regular grand prix)
2. 1999 Taurus SHO (same as GTP...make it look like a regular taurus)
3. 1998 Buick Riviera (this would probably be the best sleeper...but the heaviest)
4. 2000 ish Nissan Maxima
ANY OTHER SUGGESTIONS OF THESE TYPES OF CARS WOULD BE APPRECIATED
DO IT REAL BIG CREW #1
THE OLD DIRTY BASTARDS CREW #5
2004 Honda CBR 1000RR - It Gets The Ladies
2004 Caddilac Escalade - Brings 'Em Home
Old 08-25-2005, 01:57 PM
kman10587's Avatar
kman10587 kman10587 is offline
Send a message via AIM to kman10587
Re: Project Super Sleeper
The GTP is your best bet for cheap speed, but a lot of people will figure out that it's a GTP, so the surprise factor isn't as good. I don't like the newer SHOs at all, and the V8 has some reliability issues. The aftermarket isn't really there, either. If you get an SHO, go for an older one, with the 3.0-liter V6. The Maxima can be made pretty fast, but it's not a good choice for a sleeper. Most people already think the Maxima is pretty fast.
I think the Riviera is your best choice overall. The supercharged 3.8L has plenty of cheap aftermarket, and most people don't even know what a Riviera is, let alone that it's actually pretty quick.
My '05 Impreza 2.5 RS.
Old 08-25-2005, 02:11 PM
SuperHighOutput's Avatar
SuperHighOutput SuperHighOutput is offline
Instead of a GTP or Riviera you might look at a Regal GS with the 3.8 s/c. Basically the same car as the GTP, but with the Buick badge few will see it coming.
Also stay away from V8 SHOs! The V6s are faster and far more reliable, the V8s are notorious for cam problems that generally end in engine failure and VERY expensive repairs. The only way you should even consider on is to make sure the owner had the cams welded, and they have proof verifying that the work has been done.
Old 08-25-2005, 03:54 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
Get a Toyota Cressida is RWD and just drop either a 1JZ or a 2JZ into that sucker
Here's a hooked up one but you want one more low key than that obviously for a sleeper.
Yours truly,
Gabriel
Old 08-25-2005, 08:35 PM
FikseGTS FikseGTS is offline
1995 Toyota Supra Turbo.....
2005 Mercedes-Benz E55 AMG - 12.07 @ 116.3
1996 Dodge Viper GTS - 11.62 @ 120.61
2004 Lexus RX330
Old 08-25-2005, 10:11 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Re: Re: Project Super Sleeper
yeah, and on that note...the ultimate sleeper would have to be a Ferrari F40.
anyways, i would go with anything that has the 3800 S/C...reliable motor, reliable car, etc.
Even the GTP, very few would expect it to keep up with their sports car or what have you. I have a 2000 GTP and people are surprised when they are 8 cars behind before we hit 50mph. They expect it to have a little pep but not quite as fast as it is. Plus even though alot of cars have the same motor...performance parts are offered at large for the GTP and its set-up (ie: exhaust).
Anyways, I have intake and a custom cat-back with flowmasters and I ran a 14.3 at the track. so very quick for what you pay for.
ZedEx Crew Member #4
Old 08-26-2005, 12:31 PM
hmmm it looks like the S/C 3800s respond pretty well to mods...and being as K3 is already running low 14s with some pretty simple mods it seems like that would be my best bet....i also was wondering if i could possible put nissan 300zx performance parts on a 2000 ish maxima.....they're the same size engine i believe...so maybe?...and also i was wondering what kind of work is put in if you maybe switch the pulley on a GTP to say...a 10lb pulley....and what kind of horsepower that would be putting out....thanks for the replys
Old 08-26-2005, 11:05 PM
Andydg Andydg is offline
I second that!!!
Old 08-27-2005, 12:10 AM
Z Cars Fanatic
i will be going down to a 3.4" pulley and a reprogrammed PCM in a couple of months. maybe do a little more exhaust. that should net me mid 13's from what other people have told me. thats about as far s i would go...but i do know you can get down to mid 12's with only minor bolt-on's. so yes, the modaibility is superb IMO.
supposedly, your not supposed to go down to a 3.25" pulley until you have some other stuff done but i know people running an intake and 3.25" pulley without a gliche.
Old 08-27-2005, 04:23 PM
Re: Re: Re: Project Super Sleeper
are smaller pulleys an easy install? and what stuff would i need to have done before running a 3.25" pulley.....like upgraded internals?
Old 08-27-2005, 04:44 PM
flatlander757 flatlander757 is offline
Send a message via AIM to flatlander757
www.turbominivan.com
noone will suspect you
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
Old 08-28-2005, 12:12 AM
Z Cars Fanatic
Re: Re: Re: Re: Project Super Sleeper
they are easy to install but they recommend you use this pulley puller that you can rent from most 3800 performance places for like $30 or so. between me and you...you dont really have to use that.
anyways, no you dont need to upgrade the internals to do a 3.25" pulley. most people will recommend you get an intercooler before you do it but i would definitely get a 160 degree thermostat, PCM, intake, and exhaust work before i went down to a 3.25". i dont really think an intercooler is needed but it would help a ton i hear.
i personally am only going to a 3.4" pulley mainly because i have another performance car and i just want a little more pep in my daily driver.
check out http://www.3800performance.com
Old 08-28-2005, 03:39 PM
Vettribution Vettribution is offline
Send a message via AIM to Vettribution Send a message via Yahoo to Vettribution
Re: Re: Re: Re: Re: Project Super Sleeper
I've seen a turbo'd Maxima beat up an EVO.... I think it was a Garrett Turbo installed.. I could see if I could find more info if you want.. That thing was insanely fast, and I if I am not mistaken Maxima's stock already are quicker than the GTP's?
New Vehicle & Project:
04' ZQ8 Chevrolet Colorado, Shortbed Regular Cab I-5. (Victory Red)
Best Dyno: 8.5 psi...390 HP & 430 lbs ft TQ.
Major Mod: Garrett GT35R Turbo...
http://www.cardomain.com/ride/811544.
Please... Come get some.
Old 08-28-2005, 06:15 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
^considering that a maxima makes more hp N/A than the s/c 3800 does and weighs 200-300 lbs less the max is probably faster stock, not to mention you can get the maxima's with a manual tranny, but mod for mod the GTP/Buick's gonna respond better considering that it's already got FI. i think either car would be a good choice, if you can swing it, look into a 02-03 maxima with the VQ35, it's good for mid-high 14's stock.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 08-28-2005, 07:05 PM
Z Cars Fanatic
well thats what the GTP runs despite the 200-300lb weight advantage and whatever else.
you have to remember that the maxima may make more HP but the GTP has 280 ft/lbs of torque pulling its weight at 800 less RPM while the maxima has 246 4400 RPMs. this could make a big difference in straight line performance. plus the 3800 S/C is known for be quite a bit underrated from the factory.
reguardless, both would be good choices but liked mentioned earlier. the 2800 SC would make a better performer if plans are to be modified.
