Old 08-25-2005, 01:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question SAFC2 Install N/T
Hey all;
Im going to be buying a SAFC2 controller within the next week or 2. I've been searching, and I can only find SAFC install instructions for turbo models. When I get the controller I want the install to go as smoothly as possible because the day I install, I'm taking it to get dynoed and tuned. I hope it's not hard. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-25-2005, 01:31 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: SAFC2 Install N/T
The only difference is going to be the pin outs on the ECU. You will just need to find a pin out diagram of the N/T ECU and connect the appropriate wires.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-25-2005, 01:37 PM
david-b's Avatar
Dave is THAT guy
Cool. I got that already, so the rest is all the same then? I take it it's not that hard then?
75 Monte Carlo
Old 08-25-2005, 09:46 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
the ecu is in a different place on the nt's too. but if you can find the ecu and you have the pinout and the safc install directions then you should be set. buy some extra wire in case it doesnt come with enough to get it inside.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
