Engine Please Help
I have a 1999 Toyota camry le with 130,000 miles. The car cut of while I was driving so had it towed to mechanic because i wasn't sure if it was the battery or not. the mechanic said it was the battery, but there is also a knocking sound. Before this the check engine light had been on but assumed it was on because i didn't click the gas cap right. Took it to autozone and the code read P0401(Egr insufficient flow) the mechanic said it will probably need a new engine which will cost about 3000. I believe it's something else the car is only six years old. Please Help!
Re: Engine Please Help
Welcome to the AF!
For P0401, check the following: EGR valve stuck closed <= Most common - Clean EGR valve EGR Vacuum Switching Valve (VSV) Open or short in VSV circuit for EGR EGR valve position sensor open or short circuit Vacuum or EGR hose disconnected EGR valve position sensor Manifold absolute pressure sensor malfunction ECM malfunction As far as the knocking sound and engine dying: Does the car run with a new battery? If so, does it still knock? How often do you change the oil and what oil do you use? When was the timing belt changed last?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
engine knocking
First Thank you for replying . To answer your questions, Yes the car runs with the new battery but it is knocking . Change oil every 3000 miles or whenever the sticker tells us to.We use pennzoil 10W30 or 10W40. belt changed 1 year ago. Also i started using 89 gas because of the gas prices instead of the 93 could that have anything to do with or not. Can I check EGR on my own.
Thanks |
Yes, you can check these systems if you have a volt/ohmmeter and a vacuum source (for the VSVs).
I don't see how your gas octane would cause this problem. Even though your oil change intervals seem adequate, I would pull the head cover and see if there is any sludge build-up - particularly if you bought the car used. Your engine is prone to sludge and if it blocks an oil passage or pick-up in the pan, you may have a serious problem. Read the first post in the FAQ thread. Also, check your PCV valve.
engine knocking
The reason I brought up the gas octane was because the knocking was not occurring before the battery went bad. I have been reading online about knocking and pinging and it seems like everything said use higher octane and I just started using 89 so I don't know. Just very worried, especially since mechanic doesn't know what is going on and is suggesting new engine.
If you are talking about pre-ignition, then that's one thing. I thought you were talking about knocking as in bearing knocking. This tied in with the mechanic's recommendation better than just pinging. If you are pinging, check the timing, see if premium fuel stops the problem. You may need to put some SeaFoam through your intake and get the carbon out of your combustion chambers. In this case, I doubt you need a new engine.
engine help
The mechanic said something about a brolken rod, he said the damage is done. What is the next possible step. Please Please help. I am lost
First, be more specific about what the sound you hear sounds like.
More than likely it is experiancing pre-ignition if the EGR valve is stuck closed.
Fix the EGR problem & get a second opinion.
Toysrme257th - AIM about anything, anytime; including v6 turbos. World's second ES 300/3vz-fe Turbo. |
Good idea
^ As is the seafoam. =)
engine help
I am sorry it took so long to reply. It sounds like a hammer hitting the bottom of the engine close to number 1 piston. The rattling and knocking is constant. The mechanic said the damage was done because it looked like the rod and rod bearings are loose from the crank. He recharged the old battery and I drove it home rattlling and knocking and stalling. The knocking sounded like it would subside if I tried to go over 40 but I don't know I was afraid to push it cause the mechanic said take it easy. i also believe when looking in where you pour the oil, there is some thick black deposits, is that sludge. I am going out of my mind. Should I get a new engine, I can't believe this is happening.
Thanks |
Sounds like your engine is sludged. It is difficult to say since I haven't seen it, but your mechanic may be right. I would get all the documentation on oil changes I can find and tow it to a dealer. Read the 1st post in the FAQ thread in detail.
engine
I believe it is sludge and we are getting a run around already from toyota. There already saying we'll have to pay for them to look at it and then determine if it is sludge. The oil change receipts might be a little more complicated because we bought the car used in 2001 nad have moved twice but definitely oil changes occurred on this car thankfully. Getting the receipts is difficult because I didn't even know about toyota and sludge and I read they sent out letters to customers I didn't receive or hear anything. What is the best oil to use on 1999 toyota camry, I hear its not pennzoil. I want toyota to pay for this since the car is prone to sludge because i've been quoted with repairs of 3000.
The identity of the best oil for any particular car is strictly a matter of opinion. Any oil that meets the current quality standard should be fine.
If I were you, I would pay the dealer to figure out it's sludged. The first step in proving your claim is documenting the problem
