Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 08-25-2005, 02:32 AM
frs64 frs64 is offline
Timesert update
A few months ago , I started to rebuild my 4.0 and had to stop because I quit my job. Im back on track now. I also found that my engine had been rebuilt in the recent past but did not get timeserts , so the mechanic wasted his time. For those who dont remember me , my 4.0 overheated at highway speeds. The timesert kit cost $350.00 direct from timesert. So far the parts I need are another $750.00 , but I dont have to buy everything because I can reuse some of the existing parts.
Old 08-25-2005, 10:12 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Timesert update
How did you like the 4.0 when it was running? I hear they are pretty nice Cosworths.
Old 08-25-2005, 08:17 PM
Re: Timesert update
When it was running , It had a lot of power for a small v8. I cant wait to start it up again.
Old 08-25-2005, 08:22 PM
tedcopeland tedcopeland is offline
Re: Re: Timesert update
Hey!
How did you manage to get them from Timesert? I talked with them just today and the guy I spoke with sent me to the distributor who wanted $475 which is about $140 over what the Timesert guy said I should expect to pay!
How soon will you be done with the kit? I'd consider buying from you and then replace the certs...
Old 08-26-2005, 03:20 PM
Re: Timesert update
Because of time limits , I will be done in about 2 weeks. Im not sure if I will sell it because my father-in-law has a caddy with a 4.9. I will have to check and see if it will work with that motor. If not , I might get rid of it .
Old 08-26-2005, 03:23 PM
Re: Timesert update
To answer your question , I just called timesert direct and they sold it to me. It may have something to do with location. There wasnt a distributor near me.
Old 08-27-2005, 05:17 PM
93pb 93pb is offline
Just curious since I have the 3.5 this probably does not pertain to me,but what is a timesert??
Just looking for some education as I have never heard of this term before.
Marc
Old 08-28-2005, 07:21 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Timesert update
Marc
On the aluminium engine housings, the steel threads of the bolts and the aluminium react against each other and when removing the bolts, the threads will pull out.
There is a tool called a Timesert that is used to replace the threads with an insert.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-28-2005, 08:37 AM
Thumbs up
Thanks.
Old 10-02-2005, 06:18 PM
Re: Timesert update
When I was tightening the main bolts , the threads pulled out of the block on 2 main bolts. Instead of ordering timeserts I used metric helicoil inserts and they worked fine. Based on the torque spec ,they torque at about 40 lbs and helicoils are ok at that torque. The heads require timeserts.I should be able to start it in a few days. I ordered a new oil pump it should be here tomorrow.
Old 10-02-2005, 06:57 PM
Aurora01 Aurora01 is offline
Re: Timesert update
I beleive the correct term is a keensert not timesert
Old 10-02-2005, 11:15 PM
Re: Timesert update
Timesert is the correct name for the headbolt repair. Timesert is what GM garages use to fix their blocks.Here is the info if anyone needs it.
www.timesert.com/html/gm.html
Old 10-19-2005, 04:04 PM
Finally running and on the road. Nice car but I wouldnt recommend anyone buying an aurora at a low price and fixing the head gasket problem .This is alot of labor and expense. To rebuild the 4.0 myself cost me about $1800. Add that to the purchase price and you get $3300 for a 96 aurora. Now I have a misfire during acceleration that I need to figure out. Any ideas???
Old 10-19-2005, 11:06 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Unhappy Re: Timesert update
I wonder why GM can't have their engine manufacturers, install inserts in aluminum blocks, for the head bolts. Before they are installed in their cars. You think they know sooner or later, those bolts are going to fail. And they or one of their dealers get to make money. By selling you a new or rebuilt engine.
Old 10-20-2005, 06:59 PM
Re: Timesert update
To answer the question. From what I hear , the head bolts dont cause a problem until you pass 100k miles .That is way beyond warranty. Plus they have timesert kits for Hondas too. I just changed my wires and plugs and the miss is gone. Now I have to fix the air cond.
